Results 1 to 18 of 18
- Mar 2008
- Mass.
- 13
Hi everyone,
Does anyone have a good understanding of MSD's DIS-4 ignition system? Can you wire four MSD Blaster II coils to be triggered by the DIS-4? This is going into a 95 Mitsubishi Eclipse AWD drag car. It is experiencing terrible misfires at high rpm (7500+,) and so far we have come out empty in finding a solution. It currently has a Coil on Plug setup with MSD DIS-4 ignition. We have the plugs closed down all the way to 0.022" and it still misfires. Boost is set to 34 psi. We swapped the Coil on Plug setup to the stock Coilpack and NGK wires, no change. We change plugs every round to eliminate them from the equation.
Will those Blaster coils even work on a high rpm setup? I am guessing we can't put out enough spark energy to overcome the high boost in the combustion chamber, and figured if we setup a strong spark source, we might resolve the problem.
Any other alternatives you guys can think of?
Any ideas, jokes, flaming welcome
I know the car is not a Pro-Tourer, but figured you guys can come up with some ideas.
The car is running in the high 10s at 130+mph breaking up, and it is driving us nuts
Panos
1974 Trans Am - stock
1994 Eagle talon - drag car project
1988 Jeep wrangler - Chick magnet
