    Results 1 to 20 of 29
      Sep 2007
      Disc conversion nightmare
      Hello,
      I'm new to the forum, in fact this is my first post. Currently my brake system seems to be my worst nightmare. Recently converted my rear drums to disc with advice from another forum and a friend who use to run an oval car. Starting to feel as though I should have bought a kit and spent 3x the money. The car ran for years with disc in the front and drum in the rear with no complaints. Problems started once I changed rear to disc. The following are the components I'm using:
      69 Corvette manual master cylinder
      original disc/ drum proportioning valve
      Front: small GM style caliper (79 Monte Carlo style)
      3/16" brake line
      Rear: same caliper as front with AFCO caliper brackets
      2 psi residual pressure valve between master and proportioning valve
      1/4" brake line form master to rear split
      3/16" line across rear to rear caliper hoses
      Problem: pedal has no feedback/ feel
      When I step on the pedal it does not become firm untill pedal is depressed 2". Both front and rear brakes are applied firmly after 3/4" of pedal travel but you would never know based on brake pedal feel. I believe the car will stop, but think it will have a very weird feel. I would expect the brakes to feel super sensitive.
      Thanks in advance,
      ED
      Just North of NYC
      I can't tell from your post whether the 'vette M/C was used previously when you had rear drums. If it wasn't, make sure it has the same pushrod depth as your orignal m/c, as this can drastically change pedal feel. Also, make sure the new M/C had a bore no larger than 1"; manual brakes need one inch or less bore to stop a 4 wheel disc car well.
      But it does sound like you still have air in the system. Technically you don't need the residual valve, and the prop valve should be adjustable to dial in the balance, but neither should affect your pedal firmness. (Most "systems" stock or aftermarket have about 50% more piston area in the front to act as a built in proportioning valve, so you will likely need an adjustable prop valve.)
      Perhaps you need to bench bleed the M/C and then chase the corners again looking for air.
      Sep 2007
      Actually I did not specify that the car is a 67 Camaro.
      No this is not the master cylinder used with the drum brakes, I chose the Corvette master since it came with four wheel disc as a stock option (believe it is an 1-1/8" dia.). I feel extremely confident there is no air. I clamped each brake hose at each caliper and the pedal was hard. I did not check pushrod depth and I will also check master piston dia. I was going to change to an adjustable proportioning valve after I test drove car also thinking that it does not affect pedal firmness.
      ED
      May 2002
      Northern California
      Hello,
      69 Corvette manual master cylinder what size bore?
      !!ORIGINAL DISC/DRUM PROPORTIONING VALVE!! try a 3rd gen disc disc prop/combo valve or a full adjustible type
      3/16" brake line +1
      Rear: same caliper as front with AFCO caliper brackets that large piston is going to require a disc/disc prop/combo valve
      1/4" brake line form master to rear split +1
      3/16" line across rear to rear caliper hoses +1
      When I step on the pedal it does not become firm untill pedal is depressed 2". Both front and rear brakes are applied firmly after 3/4" of pedal travel but you would never know based on brake pedal feel. could be combo prop/combo valve or push rod length problem.
      I believe the car will stop, but think it will have a very weird feel. I would expect the brakes to feel super sensitive. should not feel super sensitive, firm with a delayed touch .
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Sep 2007
      I checked the master cylinder, piston size is 1" dia.
      Did not get chance to check pushrod depth, but will check.
      MrQuick,
      "try a 3rd gen disc disc prop/combo valve or a full adjustible type "
      "that large piston is going to require a disc/disc prop/combo valve "
      Will a fully adjustable proportioning valve from Willwood be adequate?
      Apr 2004
      OKC, OK
      First thing you need to chenge is the prop valve. It is wrong for a disc/disc combo. I would also reduce the bore size on your master to 1" as mentioned above.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Sep 2007
      Confirmed, master cylinder is 1" dia.
      Will a proportioning valve from Willwood be sufficient?
      May 2002
      Northern California
      Agreed drop the bore down. I haven't had any luck with the adjustable ones but give it a shot.
      Oct 2006
      Phoenix, AZ
      Not sure if this is something you'd be interested in but i recently found this SSBC distribution block with a built in proportioning valve, might be a simple way to solve a couple variables in your problem
      http://www.stainlesssteelbrakes.com/...ll-In-One&year=
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Jun 2006
      Katy,TX
      All Vettes after 64 had 4WD. The HD sytems used a 1 1/8 MC the "plain" used 1". Reember also especially with alot more piston size you need the volume of a larger master also to move the piston. Drum wheel cylinders need ALOT less volume to move them. The Vette MC I have to use forone car deep recess for the pushrod, darn near 1".
      You didn't mention if it actually stopped well eventhough it feels bad. Too much pedal ratio can still let you stop but loose the feel.
      My Trans Am rear calipers have a similar sized rear piston has just a T in the front line and adjustable prop valve in the rear and stops great. Origially I had too much ratio pedal and it stopped good but had no feel.
      Fontana, CA
      The 1" bore MC can work, the Combo valve (originally on the Disc/Drum cars) is the weak link here. Replace with a standard disc/disc distribution block and prop valve in the rear or use a T for the fronts and a prop valve in the rear.
      Nick R.
      Sep 2007
      Alot of information! I'm going to try your suggestions and see if I have any luck. Hopefully I can spend time on the car this weekend.
      Thanks!
      Apr 2007
      Ohio
      Yup a Wilwood or SSBC prop valve (along with others) will work fine.
      I have the polished finsih SSBC unit with the pressure gauge.
      -6Spd EFI 1980 Camaro Z28 - Street Fighter - Amongst other GM autos. Atomic Orange Z06 is next!
      Sep 2007
      Started re-plumbing front lines today. I will be doing rear next weekend with Willwood proportioning valve. I let you know how it turns out. Borrowed a hydraulic flaring tool from a friend, if you have never used one you are missing out.
      ED
      Southern Indiana
      Actually disc need less volume and more pressure rise.
      Reason being the drum brakes have to move a lot more over disc. Disc only have to move a few thousands of an inch to activate.
      I also dont like using the stock 1/4 in rear lines if it has that size. The reason is that drum brakes need more volume over disc.
      You may even need to to go down to a 7/8 master cyl.
      Good Luck.
      Lee
      May 2002
      Northern California
      I agree, 7/8" might go better. Also 1/4" to tee to 3/16" lines out.
      Phoenix,Arizona
      I just would have bought a kit, heres a good place if you are interested: https://dfbrakes.com/default.asp
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Sep 2007
      Quote Originally Posted by 70TWO NOVA
      If you only knew how many times I said the same thing. It has now become a challenge, I will probably not get a good night sleep untill the car is running again.
      Thanks for the link.
      Sep 2007
      update on brake system
      Plumbed new 3/16" lines for the rear and added a Willwood adjustable proportioning valve. Pedal height is higher and the feel is also tighter. I will be test driving in the next week after I finish a little suspension work.
      Thanks for help.
      Huntington Beach, CA
      The master cylinder you are using comes in a number of kits and in fact is the one I'm using on my car. Factory vettes in that year range used 1" for the manual m/c and 1 1/8 for power. Personally I'm using the MANUAL m/c with a power booster (booster had correct rod adapter). Witht he car off brake effort is excessive though I'm using the power brake hole on the pedal.
      Speaking of which make sure you are using the right hole in your pedal. I believe it's upper for manual, lower for power but maybe someone else can confirm since I'm going on memory atm.
      As already mentioned you need to ditch that proportioning valve. There are relatively cheap disc/disc 5 port valve that retain the brake waring light otherwise you can use an inline adjustable on the rears and plumb the fronts direct off of a T or Y block.
      I didn't change the front to rear line and currently the 1/4" line is working.
      Oh one other thing. I don't think you want to use the residual pressure valve. They don't typically come in kits that use that M/C so unless for some reason the calipers you are using require it (not familiar with them) I'd ditch it.
