Results 1 to 20 of 29
Thread: Disc conversion nightmare
09-03-2007 #1
- Sep 2007
- 162
Hello,
I'm new to the forum, in fact this is my first post. Currently my brake system seems to be my worst nightmare. Recently converted my rear drums to disc with advice from another forum and a friend who use to run an oval car. Starting to feel as though I should have bought a kit and spent 3x the money. The car ran for years with disc in the front and drum in the rear with no complaints. Problems started once I changed rear to disc. The following are the components I'm using:
69 Corvette manual master cylinder
original disc/ drum proportioning valve
Front: small GM style caliper (79 Monte Carlo style)
3/16" brake line
Rear: same caliper as front with AFCO caliper brackets
2 psi residual pressure valve between master and proportioning valve
1/4" brake line form master to rear split
3/16" line across rear to rear caliper hoses
Problem: pedal has no feedback/ feel
When I step on the pedal it does not become firm untill pedal is depressed 2". Both front and rear brakes are applied firmly after 3/4" of pedal travel but you would never know based on brake pedal feel. I believe the car will stop, but think it will have a very weird feel. I would expect the brakes to feel super sensitive.
Thanks in advance,
ED
09-03-2007 #2
- Mar 2005
- Just North of NYC
- 312
I can't tell from your post whether the 'vette M/C was used previously when you had rear drums. If it wasn't, make sure it has the same pushrod depth as your orignal m/c, as this can drastically change pedal feel. Also, make sure the new M/C had a bore no larger than 1"; manual brakes need one inch or less bore to stop a 4 wheel disc car well.
But it does sound like you still have air in the system. Technically you don't need the residual valve, and the prop valve should be adjustable to dial in the balance, but neither should affect your pedal firmness. (Most "systems" stock or aftermarket have about 50% more piston area in the front to act as a built in proportioning valve, so you will likely need an adjustable prop valve.)
Perhaps you need to bench bleed the M/C and then chase the corners again looking for air.
09-03-2007 #3
- Sep 2007
- 162
Actually I did not specify that the car is a 67 Camaro.
No this is not the master cylinder used with the drum brakes, I chose the Corvette master since it came with four wheel disc as a stock option (believe it is an 1-1/8" dia.). I feel extremely confident there is no air. I clamped each brake hose at each caliper and the pedal was hard. I did not check pushrod depth and I will also check master piston dia. I was going to change to an adjustable proportioning valve after I test drove car also thinking that it does not affect pedal firmness.
ED
09-03-2007 #4
