    Results 1 to 18 of 18
    Thread: PT '78 Malibu
      Nov 2004
      PT '78 Malibu
      Hello guys,
      Here is my Malibu. As you can see it has a glass Montecarlo front end from VFN. A custom steel roll pan out back. Lexan windshield and side windows. Up front chassis mods are a notched front cross-member, Hotchkiss upper control arms that allow me to use 12" Cadillac "A" body spindles, calipers, and rotors. Re-inforced lower control arms. a 1 & 1/8" sway bar. All urethane bushings.
      Out back a four link with a wishbone track locator with a 7/8" rod-linked sway bar riding on bronze pillar blocks Koni coilovers. The third member is a Chrysler 8 & 3/4'' with a reinforced housing. 4:88 posi. A 15 gallon foam filled fuel cell with sending unit and a optima battery fed with a 140 amp GM CS alternator from a Cadillac.
      The six speed transmission is tied to the rear end with an aluminum drive shaft. Lakewood bell housing with a Mc Cleod hydraulic throwout bearing and flywheel with a Centerforce dual friction disc and pressure plate.
      The motor is a a .030 over forged piston 454, a Competion Cams rollercam, crane roller lifters, Crower 3/8" push rods, Crane roller rockers, Isky ultra-rev kit. Lightly massaged GM square port heads, Comp Cams springs and retainers. Gm steel crank, polished rods with ARP bolts. Four bolt GM block with ARP studs. GM windage tray and trapdoor oil pan. Melling HV oil pump with .050 restrictors for the upper galley, which was deburred and polished with screened returns and magnets. Oil feed holes drilled in the front of the lifter galley to lube the B&M gear drive. Fluidamper harmonic balancer. CSI electric water pump. Radiator is a Howe aluminum two flue with Nissan Maxima electric fans. The intake is an open plenum Cutler Enterprises with a Kinsler throttle body. The injectors are Lucas disc-type 43.5 lb. per hr. A Haltech computer controls fuel delivery. An MSD-7-AL with a blaster coil with an on dash advance/retard control. Cyberdyne rich lean gauge with heated O2 sensors in the Super Comp aluma-coated Hooker headers. The engine was blue-printed and balanced.
      It has factory A/C and a stereo casette and bucket seats form a Toyota Tercel wagon. A late model Camaro console. Autometer tachometer, water temp. and oil pressure gauges. It has a six point cage from S&W with drop-out side bars.
      I proud to say I built everything and did all body and paint work at home except the transmission which was purchased new from Rockland Gear. It's due for a re-paint soon as I'm sick of the graphics and they date the car as to when it was built. I hope you like it.
