    Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 81 to 100 of 123
    1. #81
      Jan 2017
      pickering ontario canada
      Two thumbs way up
      1971 chevelle LSA 700hp -
    2. #82
      Dec 2015
      This is hands down my favorite build on here, great job
    3. #83
      Apr 2007
      Utah
      Very neat project. Thanks for sharing it with us.
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
    4. #84
      Nov 2014
      Scottsdale, AZ
      Back from Paint
      Just got the car back from Spraker Racing, they threw down some chassis grey and hot rod black
    5. #85
      Nov 2014
      Scottsdale, AZ
      Front Suspension Install
      I started with the front suspension, installing the shims and dowels in the same orientation as when I removed them. The car will have to be aligned and re-cambered/toed, but this will give us a good starting point. I am using SD20 to clean the parts prior to reinstalling them, this is what the cup teams use in between practice sessions and before the race - it works wonders.
    6. #86
      Nov 2014
      Scottsdale, AZ
      Brake Lines
      Next I had to refit my brake lines to make sure they fit, and then flare the ends. I also had to install the Tilton pedal assembly, and fluid reservoirs. I threw the steering shaft in as well, since it was easier to get it done now rather than later.
    7. #87
      Nov 2014
      Scottsdale, AZ
      Steering Box and Sway Bars
      I bolted in the rear sway bar, as well as the front sway bar and end links. The steering box is installed, and next I will need to connect the box to the steering column. So far so good.
    8. #88
      Aug 2015
      Heber City Utah
      That is going to be one bad ass ride when done !!
    9. #89
      Sep 2011
      Southern Ontario
      Awesome
    10. #90
      Sep 2013
      sw Kansas
      Nice stuff!
    11. #91
      This reminds om of the Cooper Head Chevelle from about 2001-2002...
      http://www.superchevy.com/features/6...olet-chevelle/
    12. #92
      Sep 2009
      Very cool project.
    13. #93
      Nov 2007
      Dayton, Ohio
      I love this level of fabrication. Looking good!
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
    14. #94
      Dec 2015
      Wow!!! How did I not see this sooner! Amazing project with such a cool car, its great to see a Cyclone done up like this. Keep up the great progress!
    15. #95
      Jun 2012
      South Lyon, MI
      Way cool!
    16. #96
      Nov 2014
      Scottsdale, AZ
      Project Update - Car Had to be moved from Mooresville, NC to Pennsylvania
      Just a quick update, and one of the only decent pictures I have of the car. MetalMaster had to relocate shops, so I had to throw the car together and bring it up to my garage in PA. Dad and I drove down and made it a roller for the time being, but some of it will have to come back apart. Here's a preview of the car at ride height before being loaded into the car hauler.
    17. #97
      Feb 2013
      Very cool! The stance turned out awesome.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    18. #98
      Nov 2017
      Pretty Badass
    19. #99
      Sep 2013
      sw Kansas
      I hope there's no more surprises before completion!
    20. #100
      Nov 2014
      Scottsdale, AZ
      Updates
      Since I've updated this last, we got the rear end and motor/trans back in the car, and it is back in Pennsylvania. I rebuilt the rear with some new inner axle seals, new gasket, and fresh Joe Gibbs gear oil. I had an spare set of wheels powder coated gold, and picked up some Sonoma road course tires from a cup team in Mooresville. Right now I am finishing up the dry sump oil lines, and fitting some new -16 send/return lines to the tank.
    Tags for this Thread
