    Page 9 of 23 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 19 ... LastLast
    Results 161 to 180 of 441
    1. #161
      It looks good, is that the shape of the original opening for the gauges or did you change it?
    2. #162
      Nov 2010
      Yes, That's the original shape...Name:  20150218_181609.jpg
    3. #163
      Jan 2017
      I like that you 3d printed the trim rings and then had them cnc'd. I've got a 3d printer and am pretty good with design so I have to do this more. Is it very expensive to have the parts machined? What file type do they want?
      Also sweet build!
    4. #164
      Nov 2010
      So I spent 2 hours cutting and welding up a $27 radiator hose. I tried a bunch of rubber hoses, couldn't find anything that fit good. Also printed up some reducers for my AC vents, I love this 3D printer so much I just ordered one for myself..Name:  20170930_172105.jpg
Size:  178.4 KBName:  20170930_172113.jpg
Size:  124.5 KBName:  20170921_160804.jpg
    5. #165
      I have quite a few hose pieces in the garage from my quest for something to fit my car. Nice when you can make one up yourself. That reducer came out great. I could never learn to run one. Looks good Mike. Did you do the program for that?
    6. #166
      Nov 2010
      Yes, I designed the part in Solidworks, then sent it to the 3D printer. If you need any custom parts, let me know.....
    7. #167
      Nov 2010
      Finished up the rad hoses for now, the UPS guy just dropped off my AC system. Spent the day getting it installed...
    8. #168
      Thanks for the offer ! That baby’s snug as a bug in a rug . Nice space for it.
    9. #169
      Nov 2010
      I had to use a "persuader" to get it to fit......
    10. #170
      Nov 2010
      Spent the day mocking up the steering and getting the hydroboost and master installed.
    11. #171
      Apr 2011
      Hey Mike.
      Do u need a shoehorn? What happens when you need to take off a valve cover?
    12. #172
      It looks like there's plenty of room for what you needed to do with the steering. That will make it easier to role around if you need to move it.
    13. #173
      Sep 2011
      Cool truck!
      BTW, there is a recall on some Wilwood master cylinders.
      Check the 3 digit code on the bottom.
      Mine failed going down a mountain road. Scary as h#)(
    14. #174
      Nov 2010
      Quote Originally Posted by hotrod56 View Post
      Hey Mike.
      You lift the cab.....
    15. #175
      Nov 2010
      Quote Originally Posted by Frank ZX View Post
      Cool truck!
      Thanks but that's only on 7/8" bore MC's mine is 1 1/8"
    16. #176
      Jul 2011
      Prescott, AZ
      Great job on the tunnel and dash! Those complex angles can get kind of tricky with sheet metal. We're uned in for more progress!
    17. #177
      Nov 2010
      Quote Originally Posted by Centerforce View Post
      Thanks.....
    18. #178
      Nov 2010
      Today's adventure came by way of my new center console. I designed it up, then had a local sheet metal shop cut it out of 12 gauge steel. They used a laser to cut it out, what a beautiful job that machine did. The width of the cut is only .007" and the edges are perfect, no burs or slag of any kind. I have a little work left to do tomorrow to finish it off...
    19. #179
      Sweet!
    20. #180
      Jun 2014
      is the viper engine more narrow than the hemi. it seems like you have decent real estate in the engine compartment.
