    Page 5 of 32 FirstFirst 1 2 3 4 5 6 7 8 9 10 15 ... LastLast
    Results 81 to 100 of 637
    Thread: 51 Ford pickup
    1. #81
      Sep 2012
      London, Ontario
      I just came in from the garage, that's not rust!
      73 Maverick Grabber Project
      My never ending project:
      https://www.pro-touring.com/threads/...hlight=grabber
    2. #82
      Sep 2013
      sw Kansas
      A little bit of progress at the expense of a lot of time.
    3. #83
      Nov 2010
      Novi Mi
      you make my work that I am doing on my Datsun for floor replacement look easy. I wish I wasn't living in an apt, so bad when I check project updates.
    4. #84
      Sep 2013
      sw Kansas
      I'm taking a break. Little bit of progress.
    5. #85
      Sep 2013
      sw Kansas
      I have the din slot cut. The Mustang cluster is roughed in. I filled one more hole in the floor while I was waiting for my brain to start this morning.
    6. #86
      Sep 2013
      sw Kansas
      In the words of Vince Gill: this is the last last time I should have to flip the chassis. When I ran the exhaust, I had to widen the frame cut outs to fit how I wanted to run things. Today was the day to finish that.
    7. #87
      Jun 2012
      Australia
      Country Flag: Australia
      Some nice progress there.
    8. #88
      Sep 2013
      sw Kansas
      The "I can do that better" syndrome arrived again. I haven't been happy with part of the engine cradle since day 1. I left it in the back of my mind for later. Today was later. Still not as good as I wanted but as good as I have ideas for at this time. It's boxed all the way around next to the side rails now.
    9. #89
      Sep 2013
      sw Kansas
      I got a good start on straightening the fuel lines before my tubing bender broke. It'll be a while before that task gets completed.
    10. #90
      Jun 2012
      Australia
      How and what are you using to straighten the lines with?
    11. #91
      Sep 2013
      sw Kansas
      I was using one of my benders to reverse the 90's. The 45's were easy but the 90's were what broke the bender. This probably won't look like new tubing when I give up. I haven't decided how much time I'll spend on this.
    12. #92
      Jun 2012
      Australia
      These sort of things will do the gentle bends but not the hard factory ones.
      https://www.youtube.com/watch?v=b4Ka0C7TFgc
      These look handy and could make them yourself.
      http://www.surrauto.com/documents/TS14316w.pdf
    13. #93
      Sep 2013
      sw Kansas
      Really lackluster update. I wasted hours trying to straighten the 3 fuel lines from the Mustang. I made the decision today to order a roll of 5/16 and 1/4 line and adapt to the Ford connections and start over. It only costs another $50 to go first class. I filled the last 2 big holes in the firewall.
    14. #94
      Sep 2013
      sw Kansas
      Working on fuel lines. Pics tomorrow. I'm really slow for some reason.
    15. #95
      Sep 2013
      sw Kansas
      The fuel lines are roughed in. I ordered some plastic clamps that will allow me to stack the large line on top of the 2 smaller lines running down the side of the frame. I'm not real happy with this but it still is my intention to use as much Mustang stuff as possible. I'm about to get irritated enough to spend another $500 on tools, though. I'd sure like to have the Mastercool flaring tool a friend mentioned and a real tubing straightener. I realize that brake and fuel lines are hidden but that isn't what this is about.
    16. #96
      Dec 2010
      Apex, NC
      I love this build! Glad I came across it. Subscribed
    17. #97
      Jun 2012
      Australia
      What is the 'real' tube straightener that you are thinking of? I'm planning on using as much from my donor as well.
    18. #98
      Sep 2013
      sw Kansas
      Gojeep, I am interested in the one that you mentioned that has the 4 sided rollers. I found that on my original lines, everywhere there was a 90 degree bend that it stretched the tube enough that it wouldn't straighten very well. Then when I tried to rebend, it went to pot instantly. I ended up using a block of wood drilled to straighten the new rolls. It's certainly not good enough for a show car but it was better than the hand method. The question I have is will the 4 sided one work on steel. On their website it shows copper in it. I may buy some patio door rollers and build something simple. I have a roll of 3/16 brake line to see if it's a good idea or not.
    19. #99
      Jun 2012
      Australia
      They are a good idea even if you have a new roll that has come coiled.
    20. #100
      Sep 2013
      sw Kansas
      Really poor update. New fuel line clamps.
