    Page 1 of 10 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 182
      Apr 2012
      New Art Morrison IRS
      Guys you definitely need to check out the link below. This new setup was just released by Art Morrison and it looks like they are the first company to design an IRS system that may out perform the 3 and 4 link straight axle setups. Let the comments begin!!!!!
      http://www.artmorrison.com/multi-link-IRS.php
      May 2013
      Colton Ca.
      It looks pretty but it all boils down to price point. If its anywhere near $9k you still have to factor in front suspension ,which from them is another $7k . That's the price of a complete frame swap from places like RS and Swartz. Plus its nothing new, places like Heidts etc already make a irs and people have been making there own for years now. I'd really like to see some real world data to back it up, not just because someone says its the best new thing. Numbers don't lie, but it is a really nice professional looking set up.
      Hildebran, NC
      Looks nice. Is that a D60 diff?
      Apr 2012
      Yeah I hear ya Build It Break It. However, this AMEs model stands apart from other IRS systems I have seen. The engineering and design looks to be better.
      For some real world testing take a look at the new Super Chevy magazine. the AME's test car goes head to head with the new Camaro SS on some track tests and it outperforms it.
      Quote Originally Posted by rchaskin View Post
      Yes...
      http://www.strangeengineering.net/hi...-assembly.html
      I just called and talked to AM. It can also use the stock 5th Gen Camaro rear end. The rear spindles are also 5th Gen Camaro. Axles look like they are from The DriveShaft shop.
      Beach Park IL
      Pricing?
      Donny
      Pricing?
      They said a couple of weeks. I suspect it will be somewhere between $7500-8000. The Strange diff is over $3k...plus axles...plus spindles...plus all the control arms...etc...
      Beach Park IL
      8K would be very reasonable. Wonder how well it puts power down?
      Donny
      Apr 2012
      13k is what it said in the recent super Chevy magazine.
      Socal, Ca
      Yes...
      The stock 5th gen camaro diff is not as strong as some think. A lot of 5th gen owners replace the stock diff when they add any real tq/hp to the car.
      Overall, the rear looks very promising.
      Quote Originally Posted by jtwoods4 View Post
      That seems pretty steep...I guess we will have to see.
      Quote Originally Posted by DJW32 View Post
      Yes, but the ZL1 rear should be much stronger and has a 9.9" ring gear.
      I wonder why they chose the 5th gen route and not 9". The IRS 9" solutions seem to be less expensive.
      Also, since this kit uses 5th Gen Camaro hubs, the bolt pattern is 5x120mm.
      Eastern Virginia
      Pretty cool, but out of my price range im sure
      Scot
      86 Monte SS
      May 2013
      Colton Ca.
      Like I said earlier, if it is 13k just for just the rear end it wouldn't make sense for the average Joe. Factor in $7k for AM front end and that's $20k..... Its a nice set up but doesn't seem practical price wise. Nice to look at tho
      Ahmad B.
      Apr 2012
      Woodstock, IL
      No aftermarket IRS out there is catered toward the "average joe" price wise.. Gotta pay to play!
      Just part out an RX7 or a Tbird!
      -Dale
      SchwartzPerformance
      May 2013
      Colton Ca.
      I'm not saying give it away but at a price point of $8k for a complete kit seems more reasonable is all....
      Ahmad B.
      Eastern Virginia
      If I can only find CAD models of rear C5 up Vette suspension parts & mount points........
      Scot
      86 Monte SS
      Central CA USA
      The rear diff is an S-60 9.75" ring gear Dana by Strange in their custom aluminum casting. I believe it's stronger than a Ford 9". The overall layout is close to a 5th gen Camaro, uses fifth gen aluminum outer carriers (castings), but they are machined to take the stronger/larger ZR1 bearing units. The half-shafts are Drive Shaft Shop 5th gen beef up units rated for over 1400hp.
      It is amazing to drive!
      Apr 2010
      Pittsburgh, PA
      this is just for the F bodies? which im sure will migrate down to X-bodies or are they also going to be first it make IRS for A/G bodies too ?
      72 buick skylark
      Quote Originally Posted by Nothingface5384 View Post
      It will be an option for all of their frames.
