    Page 5 of 60 FirstFirst 1 2 3 4 5 6 7 8 9 10 15 55 ... LastLast
    Results 81 to 100 of 1190
    1. #81
      Maryland
      Quote Originally Posted by shortrack View Post
      FWIW a Nascar runs 31 spline axles......
      So whats the wheelbase now?
      Andrew is right, on that the drive plate end, the axle is 1.5" and 24 spline, the axles Baddride is talking about are 1.5" 35 spline.
      The wheelbase will end up being 104", 7" longer then the original 97"
      Ron Schwarz
    2. #82
      League City, TX
      Another great build!
      Look forward to the updates.
      John Brown
      1971 Nova - Project Car
      1990 Silverado - Ridetech StreetGRIP
      Instagram @wilwaxu
      Facebook @wilwaxu
    3. #83
      oshawa ontario
      Ohhh....sorry my mistake
      Another FWIW.....a Nascar Busch (Nationwide) series car has a 105" wb and they run 190mph on a regular basis....the Sprint Cup is 110
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
    4. #84
      Maryland
      Heres one don't don't see too often, a Dana 60 center section in an oven, cooked for about 45 minutes so the tubes would push in. The tubes had about .003" press, alittle tougher then I was hoping to get in, they are pushed in so tight I really don't seem like they will need to be welded LOL,looks alot like a 3/4 ton pick up rear.
      Ron Schwarz
    5. #85
      Jun 2010
      What did you baste it with?
    6. #86
      Ontario, Canada
      Did you chill the tubes too?
      Ken
      My other car is a Vega.
    7. #87
      Maryland
      Quote Originally Posted by Dan S. View Post
      Sweat, plenty of sweat
      Ron Schwarz
    8. #88
      Maryland
      Quote Originally Posted by Kenova View Post
      Ken
      Yeah, still a really tight fit, as the tubes bottomed out in the housing and it cooled the tubes galled up.
      Ron Schwarz
    9. #89
      Aug 2006
      Vinland Kansas,66006
      Looks like there was enough room for some stuffing.LOL
    10. #90
      Charlotte
      Ron - dont know how I missed this - this is a badass looking project!!
      2014 Chevy SS LS3 / 4 Door
    11. #91
      Ron,
      How did you fixture that damn thing to even begin pressing them in?
    12. #92
      Maryland
      Its kind of helpful that a buddy runs a driveshaft shop. I gave him the tubes and snouts once I cut them to length, machined the snout to a .003" press, pushed them into the tubes, then dial indicatored them for straightness, and fixture welded and cooled them on the driveshaft machine. The welds a gorgeous. Getting the tubes in the housing required a hot housing, a cold tube, and a 1" grade 8,fine threaded rod, about 2' long, and 2 big press plates. The rod does one tube at a time, pulling between the snout and the flat spot on the inside of the housing, from the inside of the tube. Sweated my butt off ratcheting them in.
      Ron Schwarz
    13. #93
      Maryland
      Set the rear up on the frame, and put a wheel on, I have to admit I'm loving it. Will get the center crossmember and torque arm crossmember built tommorow.Hoping to get the body on Sunday
      Ron Schwarz
    14. #94
      Birmingham, AL
      That is a lot of tire! Looks like another great build.
      Stephen
    15. #95
      Indiana
      Ron, the build is moving along fast! I know they're the same size, but for some reason the pictures make the front tires look bigger than the back.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    16. #96
      Rustburg, Virginia
      Wow...just look at those big ole rollers on all four corners....is my tire envy showing?
    17. #97
      Morehead City, NC
      The next few steps are the ones I really wanna see. Never really seen an underslung chassis build in progress. I understand the concept but I want to see how it plays out. The Mustang looks lonely Ron. Take it out and give it some love before the snow falls. Wish I had some time to come help. I'm pulling the racecar apart and starting the 97 Firebird track car all at the same time.
    18. #98
      Aug 2006
      What brand are the tire's.Look's Good.
    19. #99
      Rustburg, Virginia
      Quote Originally Posted by coolwelder62 View Post
      They look alot like these:
      http://www.tirerack.com/tires/tires....num=33VR9EW710
    20. #100
      Nov 2011
      charlotte nc
      those tires are huge!?!? i don't think you'll be able to get enough heat into them especially with a UTQG of 80. you might be quicker with something smaller or adding more weight into the car.
      JohnnyCichowski.com <- ls1 miata build, race results, product reviews, yada yada yada...
