    Results 1 to 20 of 25
      Jul 2007
      Belvidere, N.J.
      Problem with Marquez Design's SS Emblems
      Just wanted to see if anyone else had purchased the billet 'SS' emblems for their camaro through Marquez Designs. I tried to install mine today on my 68 and think that there's a design flaw with it? The two threaded studs provided seem to be sticking out at on angle rather then straight back which makes it impossible to mount. I think that the two threaded bosses on the back of the emblem are on the wrong angle. If anyone else had this problem please let me know. I am going to contact the company Monday since they are closed today.
      Thanks,
      Mark
      Mark E.
      '68 RS/SS Camaro, 350 c.i./400 hp, Thumper Cam, Hurst shifter, Muncie M-21, Pypes H-pipe w/violator mufflers, 18" Rushforth Battery Wheels
      Jul 2007
      Tracy, CA.
      I would have contacted them before posting, but that's just me...
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Nov 2007
      Lafayette, LA, USA
      Quote Originally Posted by class67 View Post
      I don't see anything wrong with asking when the manufacturer is closed. Maybe there is some trick to the install he doesn't know about.
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
      Jul 2007
      Tracy, CA.
      Quote Originally Posted by fordsbyjay View Post
      I'm not getting into a pissing match with you over this, I just think that it is better to keep "problems" between the vendor and the customer....period! unless the customer is out right getting screwed.
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Jul 2007
      Belvidere, N.J.
      Lighten up will you!! I'm only asking if anyone on here has had the same problem with this part!! I'm not bashing the manufacturer but this item is not going to work as advertised and I do plan on letting them know this on Monday!!
      Mark E.
      Monterey Peninsula
      They only go on one way right...?
      www.buickfunnycar.com
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by musclecarjohn View Post
      Yes, the originals had two studs that were molded to the back of the emblem. These two studs stick STRAIGHT through the grill and than through a plate with two holes in it. Two self threading nuts hold the whole thing together from the rear. The emblem from Marquez is a very nice piece but the problem is that the two studs, when threaded into the bosses on the back of the emblem, stick out at an ANGLE and don't fit through the holes in the backing plate. It seems to me that the two threaded bosses on the back of the emblem need to be at a different angle, allowing the studs to stick straight out the back. I will post on here when I get an answer from Marquez as to what the problem is.
      Mark E.
      Aug 2001
      If I am hearing this right. Because of the angle you can't get the plate over the two studs. Have you tried putting the studs thru the plate and then screwing them into the emblem ?
      Jul 2009
      pm sent
      Jul 2007
      Belvidere, N.J.
      PM replied to.
      Mark E.
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by Charley Lillard View Post
      The whole problem is with the angle. These studs need to be straight, not at an angle. It wouldn't help by putting the studs through the plate first because they won't screw into the bosses on the back of the emblem at the angle they are currently on.
      Mark E.
      Lawrenceburg, TN
      Aug 2001
      My thought was if you started them thru the plate first there would still be play in them because they are not threading into anything at that point. Hard to explain but I have had that issue with other stuff and sometimes that is a solution. We need pics.
      Nov 2007
      So Marquez is open today, maybe give them a call to straighten this out (no pun intended)?
      Ron
      69 Camaro Redfire, thanks to
      Marquez Design | Ring Brothers
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by Nor-Cal Speed View Post
      Here is the pic!!
      Mark E.
      Aug 2001
      Wilton, CA. (Sacramento)
      looks like the emblem needs to be bent more to make the studs straight. If it was, would it match the angle of your grill better, or does it match the way it is?
      Jody
      Dec 2009
      Carson City, NV
      looks like the bosses for the studs were reversed. if they were to flip the them the studs would be at the correct angle. looks like a manufacturer boo boo...
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by camcojb View Post
      Jody
      It matches the angle of the grill the way it is.
      Mark E.
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by ChevelleNV View Post
      That's exactly what I think the problem is. Will talk to Chris at Marquez today and find out.
      Mark E.
      Monterey Peninsula
      After seeing that picture,it looks like you might be right...
