    Results 1 to 20 of 25
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by Charley Lillard View Post
      If I am hearing this right. Because of the angle you can't get the plate over the two studs. Have you tried putting the studs thru the plate and then screwing them into the emblem ?
      The whole problem is with the angle. These studs need to be straight, not at an angle. It wouldn't help by putting the studs through the plate first because they won't screw into the bosses on the back of the emblem at the angle they are currently on.
      Mark E.
      '68 RS/SS Camaro, 350 c.i./400 hp, Thumper Cam, Hurst shifter, Muncie M-21, Pypes H-pipe w/violator mufflers, 18" Rushforth Battery Wheels
