Results 61 to 63 of 63
Thread: 1967 Barracuda Fastback
01-31-2012 #61
New to Pro-Touring
- Nov 2009
- 38
Yes, It would require cutting the mounting brackets heigth down 1 inch or so. I do agree on the height of the seats the only flaw is that they tap the sunvisors in their current moment. Lowering them is the only thing they need.
I wanted to wait until I finished the floor pan work along with the transmission tunnel work and have the carpet & transmission in the car with the steering wheel in aswell before i took the seats anyfurther than lining them up evenly in conjuction with the steering column, side arm rests and width between each seat at the current state of the project. In order for the entire package to fit like it should I'd like to have the seats, shifter position, steering wheel, pedals, armrests, & seat belts and all this into play before finalizing.
01-31-2012 #62
New to Pro-Touring
- Nov 2009
- 38
Also I have My bellhousing (quicktime RM 8073),a Victor 440 intake manifold (edel 2954), 2 inch primary with 3.5 inch collectors CPPA Abody 440 headers. I'm going to be attempting at a edlebrock performer rpm head 450 - 475hp, stock crank 440. I have a 1978 cast 440 for the build.
Im going to mount the engine with a motor/mid plate and a cross member for the transmission attaching to the sub frame connectors
(old pic of eng. compartment, back to primer now. will be body color once motor/midplate work is done)
polished off with steel wool, going to go with header wrap-
The trunk divider and wheel well covers are in-
01-31-2012 #63
New to Pro-Touring
- Nov 2009
- 38
Going to go with a Mopar limited slip differential for 27 spline 8.25. Availible on summit if I cant find a used one in good condition. I would also like to change the gear ratio to 3.73 or so. besides that I finally need to mount a floor-mount style emergency brake handle and run the ebrake cables to the rea rotors. I have the emergency brake cable brackets.
New pads and rotors and rebuilt the emergency brake drum on each side of the rear.
Stainless steel brake lines hand fabricated need new pressure lines for the caliper in order to finish the brake line installation-
