Results 21 to 40 of 63
Thread: 1967 Barracuda Fastback
New to Pro-Touring
- Nov 2009
- 38
I like orange lol and it does look great. My barber school instructor said he would paint it orange too. about the colors im thinking either plum crazy, pearl white, or orange, maybe green metallic
12-08-2009 #2
New to Pro-Touring
- Nov 2009
- 38
that was a great job on the barracuda you did, PRRC, as far as stripping the steel goes I spread the paint stripper on then heat it up and then scrape most of the paint off, then i use a wire wheel and strip it to metal this is my technique if anyone knows a better way please let me know. thanks
12-09-2009 #3
- Jun 2006
- Indianapolis,IN
- 1,605
Thanks. The customer is putting the car back together himself. We hope the paint survives with out to much damage...LOL
The best way to use stripper is coat the panel and then lay plastic wrap over it to keep the fumes in and working on the paint. It works miracles
12-20-2009 #4
New to Pro-Touring
- Nov 2009
- 38
Auto x cuda glad you chimed in, your k memeber looks great.
the jeep cherokee rear discs are 5 on 4.5 and they are a bolt on deal ( jeep cherokkes used 8 1/4 rear end) Im not planning on building this car in 4 months lol. might take me a couple of years but ill get it nice & slowly. I'll post some updated pictures. My local junkyard is full of dodge darts mostly late 1970's. And a lot of oter mopars too & prices are decent.
12-21-2009 #5
New to Pro-Touring
- Nov 2009
- 38
auto x cuda you seem to understand the barracuda lol. im planning on 17" wheels all around. I dont knwo what width to go id like to run 275 40 17 on the front, and a little wider in the rear maybe 295 40 17. my car has the leaf springs in stock location and im going to go with the 1973+ k member with sway bar and discs i dont mind if the tires stick out.
12-21-2009 #6You can run 275/40/17 in front AND rear. That way you can rotate tires if you go to a track. That is a very nice feature. With a street or aggressive street alignment you will wear the outer edges of the front tires on a road course or with a lot of autocross runs. With stock hubs run 17x9 rims 5.5" backspacing. You will need to fold back 1" by 3" section of the front fender lip.
I just folded back my fender lips last weekend. I have pictures. I went a little too agressive with a 2" fold back.
You can't really have the tires sticking out or the tire will rub, chunk, and cut on the fender top.
You can run the 275/40/17 in the rear with 5.5" backspacing but you will need a rear end 2" wider than the stock A-body 8 3/4 rear. That is actually will save you some money, because that calculates out to a 65-67 B-Body or a 68-70 B-body. Check a width chart online.
A 65-67 B-Body 8 3/4 rear end is about $250-350 used WITH big bolt pattern and a 742 case center section open rear highway gears. A 66-72 A-Body 8 3/4 rear end is about 400-500 used WITHOUT big bolt pattern and a 742 or 489 case center section open rear highway gears. THEN you have to buy large bolt pattern axles for it for an additional $250+ or so with bearings. See where I'm going with this??
Now to use the 65-67 B-Body 8 3/4 rear end, you'll have to relocated the spring pads. I'd wild guess $100 at a rear end place.
Must read this about fitting 17" rims on an A-body by Clair Davis: http://www.moparfins.com/CLAIRDAVIS/Cobra_Wheel.htm
Just pointing out an alternative. I know you have a 8 1/4 in your hand now. Not a bad choice, IHMO. But you will have to run a 275/40/17 on a 17x9 with 4.5" backspacing
I don't think a 295 40 17 is going to fit even if you fold over the rear fender lip on topwith lowered suspension and stock frame rail location. Careful, some of the drag type guys will probably say they fit a 295/50/15 or something back there. BUT they have the rear end all jacked up drag style.
Are you on www.forabodiesonly.com ?? There are some good threads there on this subject.SPRING FLING XXV
April 16 & 17, 2011
Woodley Park, Van Nuys CA
800+ Mopars, 300+ swap, 40+midways
Speed Festival Track Event
5th annual, Thursday, Willow Springs, 40+ Mopars
Track Video
12-22-2009 #7
