    Page 7 of 10 FirstFirst ... 2 3 4 5 6 7 8 9 10 LastLast
    Results 121 to 140 of 183
    1. #121
      iceland
      Country Flag: Iceland
      Quote Originally Posted by Bob's68 View Post
      Im loving the build yeah your build thread is how i found out about matts classic bowties
      Things..Bob's68
      http://www.mattsclassicbowties.com/ Are very good
    2. #122
      iceland
      The last parts are in
      front cover gasket and seal
      rear cover gasket and seal
      misc plugs
      head gaskets
      exhaust gaskets
      oil dip stick/tube
      rings
      pan&valley gasket .
      cam bearings
      rod bearings
      main bearings
      rocker arms
      damper ls3
      crank bolt
      tensioner water pump
      bolts attach
      shipped last week Ls3 oil pump with o-rings for valley cover,oil pump is blueprinted higher pressure and volume and also the Pushrods
      So assembling cane start
    3. #123
      Sweet looking parts!
    4. #124
      Aug 2010
      wichita ks
      VERY NICE! looking forward to following this build.
    5. #125
      Oct 2010
      Iceland
      Quote Originally Posted by 1971CHEVELLE View Post
      Chevelle does look good in Pearl White with the red interior but there is one 1970 Chevelle project here so 2 Pearl White Chevelle in small places so for the moments it is out
      but thanks
      I agree two white chevelles on Iceland would be to many, BTW cool projegt! or in Icelandic “Glæsilegt hjá þér Bjarni”
    6. #126
      Apr 2010
      Chandler, AZ
      Is it possible that you can post some pictures of how you made those seats mount in the front and rear?
      I'm in the process of mine as well and I would appreciate the help. [email protected]
      70 Chevelle LS3 T-56 Whiplash Rushforth Wheels.
      Paint design by Jason Rushforth
    7. #127
      iceland
      Quote Originally Posted by AZSaleen04 View Post
      hi
      I didn't have to make the seats mount used part of the G.T.O floor
    8. #128
      iceland
      Small update on the project this is on its way from the states
      the Firewall Cowl Panel was getting a little thin
    9. #129
      Wow thats looking amazing there is quite a bit of time involved great job.
      I was looking and didn't see if you posted or not but what color blue is that on the car in the early stages before you welded everything together? Seems to change to bright teal when the camera flash hits it.
      Anyhow great progress and I can't wait to see more pics.
      Paul
    10. #130
      iceland
      New year and a new plan
      More old out for new
      and in the pipeline SS dash
      but plan for the seat not sure , but this
      can look like this
    11. #131
      iceland
      in most household is a dishwasher and my oil pan from this corvette
      well it is clean now
      Back together
    12. #132
      Atlanta, GA
      hi
      Did you weld the GTO trans/drive shaft tunnel in the Chevelle pan? Project is looking good
      Lamar
      00 C5 hardtop H&C 436 rwhp with an 04 Z06 Suspension
      70 Chevelle SS396
    13. #133
      iceland
      Sometimes things are not as good as they look , wean the cover come off.
      both frames damage and needed to repaired
      both wear cut and welded back together .
      primer and painted
      this one needs to be relined
      and this one two
    14. #134
      iceland
      getting ready to put back together with contact spray
      give it time to set
      Looks good and fits well so well that I didn't use tools on the bolts only my fingers
    15. #135
      iceland
      Ok removing seat cover from GTO 2004-06 1o1
      Start with loosen these 4 springs
      with them out of the way you can lift up the plastic
      now you can get the headrest mounted
      all you have to do is push is push this in
      and then it is lose and can be removed
      Now the Seat Recline Lever YOU can´t remove it and you don't need to
      the cover comes off without removing it
    16. #136
      iceland
      Is this the right tool for the job ?
      it pinches the parts well together and good space to work with it
      does it work :?:
    17. #137
      Dec 2007
      British Columbia, Canada
      Nice progress. Just curious, with your GTO seats, did you cut the bottoms down at on on the front seats? I have the same seats and am trying to fit them in my 68 Acadian (Nova) and I find they sit quite high. I was hoping to keep the power controls, but trying to find a way to bring them down some. Keep up the good work.
    18. #138
      iceland
      Quote Originally Posted by scherp69 View Post
      No I didn't cut the seat. I was gonna use the GTO floor in one piece in to the chevelle and lower
      the floor. But it was not an easy task in my little garage to do it well so I decided against it
      but I'm working on it......to find a good solution for it
      And here is what I'm doing today
      Ok I have primer and painted the area that go on the firewall
      same with area on the firewall
      primer and paint remove from the welding points
      and same on the firewall
      all welding points ready
      and it fits
    19. #139
      Charlotte
      Nice update!
      2014 Chevy SS LS3 / 4 Door
    20. #140
      Jul 2011
      Nashville/ Tampa
      Any updates? Cruising Laugavegur yet?
