Results 1 to 19 of 19
Thread: Rack & Pinion Fitting Question
10-21-2008 #1
- Jan 2005
- 29
I have a Fox-body Mustang R&P in my '67 Camaro (also an aftermarket subframe) and I can't quite figure out what fittings I need to fab my power steering hoses. I know that the inlet port (high pressure) is 14mm x 1.5 but it looks like the return port (low pressure) is 5/8-18. This doesn't seem right but I have a friend that had a Mustang and he said that it had metric and SAE intermixed. I can see differences from component to component but a mixture on a single component doesn't sound correct. Anyone been down this road before that may have a suggestion or remember what fittings they used?
10-22-2008 #2
- Jan 2005
- 29
I'll go ahead and close this thread out for future ref...
I posted the same question on a Camaro site and someone on there verified that there were indeed two different fittings (SAE & metric) on the Mustang R&P. I would've never guessed such a thing but then again what do I know.
10-22-2008 #3
Wait! Stop!
Make sure by the year of rack you have. Early racks use all SAE fittings, and AFIAK, later racks use all metric!
It is a common misconception that SAE racks use metric and SAE, but it's wrong. It does work, but it galls the threads. The pressure side is 9/16-18 thread, and the return thread is 5/8-18. We manufacturer our own fittings to solve this problem.Matt Jones
Mechanical Engineer
Art Morrison Enterprises
