Results 1 to 19 of 19
Thread: Richmond ROD 6 sp
01-30-2008 #1
- Jan 2008
- Edmonton, Alberta, Canada
- 15
Richmond ROD 6 sp
AHH so many questions to ask. Well I guess I'll start out by asking if anyone out there has succesfully installed a Richmond ROD 6 speed in a 1980 camaro with out major tunnel mods or relocation of the shifter position. First of all I'll state that I have chosen the Richmond tranny because it appears to be much smaller in physical size (than a T-56) and is rated to 450 ft lbs. Although I am more partial to a top loading Transmission, I have found that a T-56 swap will not work for me due to alot of tunnel mods (to keep drive angle correct), and the GM aftermarket is only rated for 400 ft lbs. My car is an original 4 sp car and I have just installed a 540 hp, 480 ft. lbs 383 cid engine. My goal is to make these mods if possible without cutting any sheet metal to make a 6 sp work. I guess my question is am I barking up the wrong tree ?? I would really like to have a 6 speed in the car. My other option is a TKO 600 which should drop in other than a modded drive shaft and tranny mount, but once again it is only a 4 speed with an overdrive. I appreciate the time taken for those who read this post and pls be patient because this is all relatively new to me.
One other note, my plan for this car is to be a daily driver/ pro-touring type car. In the event I get some positive feed back on the instillation of the Richmond transmission, the following would likely be my choice of driveline gearing. Any advice would be much appreciated.
1 - 3.04
2 - 2.13
3 - 1.57
4 - 1.24
5 - 1.00
6 - 0.62
Built 10 bolt 8.5 ring, Moser axles, C-clip eliminators, and if possible GM Posi with a 3.42 diff. ratio
27 inch tires.
Redline = 6200-6500 RPM
Thanks Again
C.C
01-31-2008 #2I've got an ROD in my '68 Camaro. It fit O.K., even with 1/2 lower body mounts. The side of the tunnel needed clearancing for the shifter rods and shifter itself. On a different '68 I built I installed a TKO with stock height body mounts, and ended up spacing down the subframe a little bit more, as the trans hit the top of the tunnel pretty bad. The Richmond needed an adapter that replaces the top of the Long shifter to keep the stock console. You might try to contact Long and ask about shifter placement in a second gen.
01-31-2008 #3I have one in a 69 Corvette behind a fuel injected 468. No tunnel mods needed to slip it into that car, only a cross member mod. Long makes a good shifter assembly and I'd agree to check with them for a 2nd gen.
It is a good trans and has worked flawlessly in our car.Chris McDonald
02-04-2008 #4
- Jan 2008
- 15
O.k thanks for the input fellers. It kinda looks like not many take the 6 speed route.
02-04-2008 #5
- Jan 2008
- 15
By the way what do you guys think of those driveline numbers. Do they sound reasonable??
02-04-2008 #6I used the 3.28 1st, and .76 OD, with a 3.31 rear gear. I love it. It starts out easy and OD is fine. Gear spacing is perfect! Unless I wanted to only drag race, I don't think I'd pick any different. I used the Car Test software to try out a lot of different gearsets before I got my trans. With the 3.31s I rarely get it to 6th around town. I think with 3.42s it might be a bit better, but I had my rear already. The lower OD can be too much unless you've got a low reving fuel injected motor.
02-05-2008 #7
- Aug 2004
- 23
Chris,
I don't understand the need for tunnel mods with a T56 in a 2nd gen Camaro. Just need a new hole for the shifter. There are a number of guys over at http://nastyz28.com/ that have done this swap without a problem.
I'm just getting ready to install my T56 and a BBC 509 into my 79 Z28 ( 4 speed car).
John
02-06-2008 #8
- Jan 2008
- 15
Thanks for the input HILROD, my original thought was to drive the cruising speed RPM's way low for long trips. I calculated roughly 1600 RPM at 60 mph with the 0.62 OD. The 0.76 option was about 1820 RPM at 60 mph.
02-06-2008 #9
- Jan 2008
- 15
79 Zed I had a look at some of the post at the nasty Z28 forums, and I gather that the tunnel may need to raised to allow room for the bigger tranny. I say this because the tail shaft will not be high enough to maintain proper drive line angle. The forums also indicates that the shifter position is also moved back 2", which means that the shifter opening must be trimmed ( by how much not sure). This would also alter the console position and I really don't want to change the car that way.
Don't get me wrong I do appreciate the input, and would really like to see the steps you take to install that tranny. I still have not made up my mind yet on which way I'm gonna go. The price of these transmissions are huge here in Alberta, and I don't want to be disappointed.
ROD with shifter $3200
Tremec no shifter $ 2800
Thanks for your time, and pls send some pics this way during your project.
02-06-2008 #10
