    Page 7 of 9 FirstFirst ... 2 3 4 5 6 7 8 9 LastLast
    Results 121 to 140 of 179
    Thread: '68 Firebird
    1. #121
      Amsterdam,The Netherlands
      Country Flag: Netherlands
      I got Corbeau's but they can go now. Bought myself some Sparco Milano's with some better lateral support. Matching the new upholstered back seat.
      Wauw Sema, must had a blast. Curious about your idea's.
      Cliff
      1968 Firebird
    2. #122
      Thanks lenie, Martin.
      Cliff
      1968 Firebird
    3. #123
      Jun 2010
      Cliff, any album with bigger pictures of the bird? Really like the stance!
      Gui
    4. #124
      Mar 2011
      Do you also have a pic of the gauges buddy? Nice bird, by the way.
    5. #125
      Thanks Hoover.
      Cliff
      1968 Firebird
    6. #126
      Feb 2012
      the Netherlands
      2 pics of your Bird I made last year
      Very nice car, man! Me and my dad are building a '69 Javelin. In a few years, we are present on this meeting too, haha.
      Manuel Compaan
      the Netherlands
    7. #127
      Thanks for the pics! Pretty rare car in our small country that Javelin, good luck wrenching!!!
      Cliff
      1968 Firebird
    8. #128
      Oct 2011
      Nice car, what mirrors are you using?
    9. #129
      Quote Originally Posted by bimmen325 View Post
      I have to check, mirrors are universal. No car type specific
      Cliff
      1968 Firebird
    10. #130
      Quote Originally Posted by Lenie View Post
      Hi Cliff, other than the black aluminum housing, what are the differences between the fesler tail lights and the stock tail lights? Been debating on buying a set if there are major differences. Thanks
      Hey Lenie, sorry buddy, just saw your question.
      Not much differences. The Fesler units feel more beefier, nice glass though. They seem to stick out a little more of the tail panel, or the old units were just shot.
      Cliff
      1968 Firebird
    11. #131
      Been trying to work on the exhaust system. Coated Doug's headers and the Magnaflow kit from Frank.
      Install of the headers was as easy as you can get. The engine didn't had to be lift at all or such. Ground clearance is optimum (old set up with Hooker gave only 3" clearance).
      For all you Poncho guys with first gen Birds; there is a major Oil filter (housing) -to - header - clearance difference between round port and D-port Doug's headers. As also seen on Joe's thread ('67 Re-birth) on this board.
      pics say more...
      Headers installed with 110 dgrs filter housing:
      Tried smaller diameter and shorter oil filters but no difference
      I was able to track down a straight oil filter housing from a '64 engine (right):
      By-pass valve removed an tapped for 3/8 plug
      problem solved:
      Cliff
      1968 Firebird
    12. #132
      Oct 2009
      Reno, NV.
      Which filter did you go with? NAPA 1258? Also, I've been reading up on that bypass spring in the housing and am undecided on leaving it as is or doing what you did. What are you're thoughts on that? What swayed your decision to block it? I'm having a hard time finding a good reason to go either way, there's solid arguments for both
      Joe M
      '67 Firebird
      My build thread: https://www.pro-touring.com/showthre...irth&highlight=
    13. #133
      Quote Originally Posted by 67rstbkt View Post
      Ended up with the 1258 (bigger volume). Since the bypass spring is almost 50 years old and the housing (Kauffman) I've been using for the past couple of years doesn't has the bypass at all and that all oil passing the filter is actually filtered made the decission a lot easier. Not a lot to find about this and opnions differ. Couple of Poncho engines builders also advise to block the bypass.
      Cliff
      1968 Firebird
    14. #134
      Filter done. Next the exhaust; stainless Magnaflow X-pipe. Ordered an extra set of 12" stainless collectors/reducers and had them expanded to exept 2.5"pipe. Angle of the collectors had to be altered because the headers are pretty tight to the floor and not centered in the transmission crossmember.
      mock up and ready for welding
      Cliff
      1968 Firebird
    15. #135
      Sydney, Australia
      Country Flag: Australia
      Nice work....theres also an oil filter mount kit that rotates the filter towards the rear...for use with the original Long Branch style Ram Air cast iron headers.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
    16. #136
      G-link
      It has been a busy week, welding and installing the G-link. looks good, drives nice (small test ride) but stance is far from what I wanted.
      Cliff
      1968 Firebird
    17. #137
      Dunwoody, GA
      Are you going to be able to adjust the stance to suit your desires, Cliff? Glad to see you still making changes and updates to the car
      Trey
      ~ Jon Hammond
    18. #138
      May 2008
      Quote Originally Posted by CliffS View Post
      Thanks for the kudos guys!
      Small update on the interior. I replaced the billet steering wheel for a Momo unit with a Poncho touch.
      Where did you find the poncho horn button for the momo wheel?
    19. #139
      Quote Originally Posted by WS6 View Post
      Hey Trey. A lot has been discussed on the web about the G-link. Chris Alston stepped up and did a Article about the 4 link. Chassisworks has two lowering kits available now (5/8 - 11/4). Got one on order now.
      Cliff
      1968 Firebird
    20. #140
      Quote Originally Posted by DaveD View Post
      Dave, I took a GM horn button (source Summit or Classic Ind) and exchanged the innerparts.
      Cliff
      1968 Firebird
