Results 101 to 120 of 331
11-01-2007 #101
Originally Posted by trapin
If you can help me in ANY way, I would be greatful!
I need to get my hands on a wiring harness to make the engine run.
As things move further along, you'd be welcome to come check it out!
11-01-2007 #102
- Oct 2004
- St Louis, MO
- 373
Call Speartech no the wiring harness. They can make it exactly what you need and none of the other crap you don't.
11-03-2007 #103
- Apr 2007
- 42
I have to say that this a nice project. It has given me some ideas about swapping a ecotec into a corvair. I will be watching this to see how it turns out. I have read that lightly modified turbo ecos can make 300hp easy. With the light weight of that Chevette and engine combo, that should be a real quick ride.
11-03-2007 #104You are right the passlock sensor will cause the car not to start. The ecm will also look for all the other modules that are in the car like the SDM or EBCM even the IPC. Somehow that part of the ECM will need to be disabled.
Originally Posted by Fuelie Fan
Nate Kauffman
"She sips nitro with phase 4 heads, 600 horsepower through the wheels, shes meanness set to music and the bitch was born to run." Mad Max
11-03-2007 #105
- Oct 2007
- Lubbock, TX
- 384
Man, those CF light covers look sick. Anymore pics of that? What else to plan to plan to wrap in CF?
11-03-2007 #106Thanks! Those are about the best pics of the headlight buckets I have right now. I plan to probably do carbon fiber on the rear view mirror, tail panel between the taillights, a few interior pieces, and the maybe the lower front valance.....I changed my mind on the hood for now. I don't want to go overboard and have it look too outta place.
I tried to get my torpedo heater working in the garage but it won't stay lit!!!....it's been pretty cold and its only gonna get worse. Luckily my basement is pretty big and will allow some projects to be carried out inside. I have a lot more planning to do before I start the chassis and cage....and a lot more parts to buy!....damn...
As for the wiring situation.....I guess I just gotta try and find a totaled 08 Solstice GXP, buy the wiring harness and ALL other components or buy it from the dealership.
AGAIN, ANYONE HEAR OF AN '08 SOLSTICE GXP in a Salvage Yard or being parted out.....PLEASE LET ME KNOW!!!
11-03-2007 #107
- Aug 2004
- Youngsville, NC
- 82
Have you checked this place out yet?
http://www.solsticeforum.com/forum/s...ghlight=parted
They may not have what you need, but it sounds like you can put your name on a waiting list.-Jesse
11-03-2007 #108I owned a 79 4 door Chevette back in 84/85. There was even a Chevette Club where I grew up in Flint(MI). Those guys had their cars all pimped out with wire wheels,white wall tires,tinted windows and killer stereo systems. I saw a silver 2 door with a supercharged v6 at the Woodward Dream Cruise this summer. I noticed your floor boards were rusted out. Chevettes were famous for that. I had a big hole in mine also. I hated driving that car in the rain.Well good luck to you sir. Looking forward to seeing you cruising the Detroit area next summer.
11-04-2007 #109The other issues you'll run into:
1. DBW- drive by wire. All gen 2 Ecotecs are DBW now. It can be programmed out if you switch or modify the TB.
2. The CAN protocol , and the way it requires interaction with the BCM (stuff like gas cap venting, speed sensors, etc). Speartech and a few others can defeat some of this for you. In the interest of time and effort, I'd stick with the factory ECM- the DI engines run slightly different fuel/spark corrections. I have yet to see an aftemarket controller on an Eco DI (on the street, at least).
3. If you can, the IRS out of a Solstice could be made to work; you can upgrade the center 'chunk' by using a CTS-V or GTO diff.
On a good note, I know of a GXP that is making 445rwhp already; he's finishing up a kit for release. You'll have no problems getting 300hp out of that- easy day!
11-06-2007 #110
