    Page 5 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 15 ... LastLast
    Results 81 to 100 of 331
      Sep 2007
      Quote Originally Posted by West Texas Z
      I think this is an awesome build, but I'm not a fan of the white grills in the front. IMO, I would put a front mount intercooler behind the black pieces. Just my .02.
      Would look killer too. KEEP UP THE GOOD JOB!
      Thanks! The grills are painted silver....... The front mount intercooler will be mounted below the bumper.
      I'll be making the lower valance outta carbon fiber and will be mounting the intercooler in its location ....
      Denver, CO
      very very cool. i've always wanted to do this motor swap in a vega. very kick ass.
      Feb 2007
      USA, TN
      There is a place that speciallizes on converting LS wiring harnesses for muscle car installation. Perhaps they can convert yours. I'm trying to find it, but I can't.
      Oct 2007
      Lookin good bro - thanks for the link to the build.
      Ok...may be considerd un-holy and more gasser than pro touring...but for a cheep front end you can get the staight axle out of any 2wd Jeep XJ (Cherokee) Section and sleve the tube to the width needed and fab up the new suspension arms. If the motor is tucked back in the fire wall far enough the axle tube could clear the oil pan, or you could use the stock knuckles and make a drop center section...out there I know...
      For the rear end, you could look for a Zuki Samuri rear end. They are very narrow and el'cheepo! it's like a shunken 9" so welding up any sort of linked rear suspension to the housing is easy...The offroad after market supports it with lockers and all the gear ratios you could want.
      It could get you on the road untill you can build a narrowed 9" or crib an IRS out of a late model SUV...
      I gotta get by your shop and check it out in person!
      Sep 2007
      Spent yesterday setting up the rear valance for fiberglass and then it will be overlaid in carbon fiber. Its still all fiber glass..I will post pics when completed..(probably be a while)
      I also hated the way the car was sittin up so high....looked like a gasser, which is fine, but I like low. I just removed the springs completely and the lower A-arms are resting on the bumpstops.
      For a little more than 2 weeks worth of work, I'm pretty happy with the progress. The car looks much better in my opinion, especially with the front bumper narrowed and recessed and TUCKIN' 13"s!!!!
      I'm going to pick up my Spearco intercooler/polished pipes tomarrow. It will be interesting to see if it will even fit behind the bumper and between the bumper brackets. My friend went to pick it up last week and their ebay sales rep. was sick and for some reason it couldn't be released......even though he had my reciept showing it was paid in full and just needed to be picked up from their other location from which I got the engine/trans.
      Sep 2007
      Well I had to cut up the front bumper a bit more than I planned...I made the openings even with the hood grills and transition from the lower valance. I had to do this to allow a direct flow of air to the intercooler. I think I will be extending the middle bumper section down to the lower valance and will be adding a curved piece that will be welded to the bumper and will cover the endtanks and will transition into the intercooler...(Hard to explain, I post pics when further along.
      I really wish I coulda kept the bumper the way it was....it looked so nice!
      I had to do absolutely nothing to the bumper brackets in order for the intercooler to fit. I have about 1/8"-1/4" On either side of the endtanks between the bumper brackets stand-out tubes. I used 7/16" solid round stock for the intercooler mounts, drilled and taped one end and welded them to the bumper brackets. Fits great but I need more stainless intercooler piping....this intercooler was off a Cobalt SS and the tubes are definetly not meant for this car or engine.
      I also called Jegs today to see where the hell the Chassis/12pt. Cage was that I ordered 2 weeks ago. WELL....."All we have on the computer is the tub kit you ordered".......WHAT!!!! The guy even read everything back to me gave me a total, took my card # and said it should be there by the end of the wek or at the latest the end of next week if something is not in stock.....
      SO, I had to REORDER the $h!t. The chassis rails should be here this week and they have to band up the cage and then ship it out. I was pretty upset to here this! I guess I'll have to look on the bright side and keep working on the body and other stuff that needs to be done before I get too sidetracked on the chassis and cage.
      Heres some pics of the intercooler and clearance shots......
      Dayton Ohio
      wow its strange seeing a intercooler on a chevette
      Albemarle, NC
      wow. just wow.
      that is an awesome chevette. and i give my buddy crap for building an AMC spirit. after this, ill have to tell him to take it up a step. gotta keep up with DF!
      Michael
      Michael Crawford
      If it's anything like earlier ecotecs, what you'll need is the body control module and ignition switch, as well as the associated wiring. It's an anti-theft thing, and unfortunately it's over a comm bus instead of being a simple analog or digital input.
      Elizabethtown pa
      Quote Originally Posted by Fuelie Fan
      You are right the passlock sensor will cause the car not to start. The ecm will also look for all the other modules that are in the car like the SDM or EBCM even the IPC. Somehow that part of the ECM will need to be disabled.
      Nate Kauffman
      "She sips nitro with phase 4 heads, 600 horsepower through the wheels, shes meanness set to music and the bitch was born to run." Mad Max
      Nov 2001
      Sacramento Ca
      not to mention the fuel pump cutoff that detects roll overs and crashes.
      Tony Langlois
      1966 Corvair Monza
      Rochester, NY
      Man seems like everyone had just figured out EFI and GM throws us direct injection. Im confident you'll make it work, though. Lots of resource here.
      Freakin cool build by the way. The "Bad Seed" that Hot Rod magazine did a while back gave me all kinds of crazy ideas.
      Sep 2007
      I've been doing a lot of cleanup on the car lately. That Zeibart rust coating is a major pain in the ass to remove! and messy as hell! I want it clean though. Might I add the stuff works great!!! I cant believe just how little rust this car has!
      I bought some 1x1 square stock today to do the fender support braces and the core support brace. I think that will be my weekend project....along with more cleaning.
      The rear valance is coming along and should be ready for carbon fiber by next week(been lazy about that one)
      I recieved a bunch of gussets and brackets in the mail today.
      Heres a few pictures of the headlight buckets done in carbon fiber.....I still gotta do another coat of epoxy.
      Sep 2007
      This came today....
      Jul 2008
      ohio
      is this the kit they sell throught jegs??
      Quote Originally Posted by dafabricata View Post
      This came today....
      Denver, CO
      Bump!
      iceland
      Country Flag: Iceland
      Nov 2007
      Oro Valley, AZ
      I do have to say this looks like a killer project! I saw a pic in a Readers' Rides section of (I believe) Car Craft... it was an '80s Chevette with 17s... ever since then I knew these econoboxes could look cool :D
      Up until reading where you're actually from, I figured it would be MI seeing the pics of Schram (ordered a fuel pump from there last week). I live up near Flint.
      On the wheels, I'm with sticking with the C6 wheels, I think they look awesome on the car :D The satin/matte/(whatever that finish is) looks perfect with the rest of the car.
      For the engine harness, have you checked out Howell EFI (www.howellefi.com)? Bill Howell actually used to work for GM on the EFI systems to my understanding. They do LS harnesses, and may be able to do one for the Ecotec.
      I'm as anxious as everyone else to see this thing done! And congrats on a new house! :D
      -Darren-
      '78, '81 Malibu, '92 Sierra
      Quote Originally Posted by joemac View Post
      ...not only am I talking to myself as I'm going down the road I'm starting to answer myself and laugh at my own jokes-out loud...
      Harriman, Tennessee
      Quote Originally Posted by Doober View Post
      I wouldn't buy another harness from Howell if it were 1$ and came with a team of techs to help me install it.
      Shiny Side Up!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Dayton Ohio
