    Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 21 to 40 of 101
    Thread: 70 chevelle
    1. #21
      I have the combo on the right in the picture above. I tried the wide/short mount with the short stand and the tie rod clearance was too much. Tony if I were you, I would go ahead and modify that pan right now. Mine is already installed, and I am too far into it. It would take a very small notch to give you the room that you need to clear the tie rods and place the engine as low as possible. Believe me, this will make life easier when you go to set all of your angles. Here is an extreme example of what can be done and his results are very good. Smooth as a new car he says:
      http://www.chevelles.com/forums/showthread.php?t=213271
      After messing around with the driveline angles for the past 3 days I think I have it where I am happy. The ultimate test will be on the road, but I ran the driveshaft to about 5000 RPM and it seems pretty smooth. I did that several times today at various angles and I could definitely sense a harmonic at other settings.
    2. #22
      Dec 2007
      Carlsbad, Ca
      andrew, what angles did you end up with. are they in relation to the frame or level ground at ride height?
      thanks, Tim
      Tim
      Build Thread Link
    3. #23
      Chicago
      Andrew,
      I'm waiting for my spindles to come back from anodizing. Once they do I'm going to install my suspension stuff and establish a ride height and go from there. If you don't mind sharing whats your ride height and driveline angles. I know you said your car was sittin a little high in your thread did you end up getting it right yet. How is she running?
      Tony L
    4. #24
      Quote Originally Posted by 70 Chevelle
      Andrew,
      I updated my thread. I have not driven it yet, but I am hopeful that I am on the right track to getting the vibration smoothed out.
    5. #25
      Chicago
      Just got them back from ATS today. Had to have the tapers changed so I had them anodized while they were there.
      Tony L
    6. #26
      Sexy!!!
    7. #27
      Chicago
      Thanks man, this thing feels like it's gonna be years at this pace !
      Tony L
    8. #28
      It took me 4 years to finish my GTO. Just work on it a little at a time. Never forget that it is a hobby for your enjoyment. No need to rush and get burned out on it.
    9. #29
      Chicago
      I received my seats and belts and some other parts and figured why not try making my own door panels. Started by making a glass panel to replace the cardboard.I picked up some insulation foam and shaped it till I got a shape I liked and I'm in the process of transferring to mdf so I can make a mold and eventually make them completely out of glass
      Tony L
    10. #30
      Chicago
      Foam mock up
      Tony L
    11. #31
      Chicago
      starting mdf .Does anyone know why I can only add one attachment at a time ? If I try to add more than one the window closes?
      Tony L
    12. #32
      Chicago
      A little progress
      Tony L
    13. #33
      Hey Tony,
      Are you using MDF for the door panels?
    14. #34
      Chicago
      I'm only using mdf to make a temporary panel. Once the mdf panel is done I'll use it to make a female mold then the end product will be made from that mold in fiberglass, mabye carbon. No mdf in the final product other than very small sub box
      Tony L
    15. #35
      May 2008
      SoCaL-Pico Rivera
      When can you start on a set for me.......
      looks great
    16. #36
      Chicago
      Had some time this week so I blocked and smoothed and rolled all the edges. I put them in primer tonight and have them at the point where I can pull a mold from it. This is taking a ton of time I thought the dash insert was bad but these are much worse.
      Tony L
    17. #37
      Awesome job they look great. The way you have them set in the car the black part looks finnished !
    18. #38
      iceland
      Country Flag: Iceland
    19. #39
      Chicago
      After an insane amount of work I finally have a mold.
      Here is the master mounted to a board and sprayed with pva.
      After gelcoat
      Fiberglassed and framed for support
      Finished
      Tony L
    20. #40
      Chicago
      Hopefully by next weekend I'll be able to pop my panel out of the mold
      Tony L
