    Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 81 to 100 of 101
    Thread: 70 chevelle
    1. #81
      Nov 2009
      illinois
      if you don't wish to make anymore panels. would you be interested in selling your molds? i would be interested in that. i too can appreciate your accomplishment.
      rich
    2. #82
      Nov 2009
      illinois
      double post
    3. #83
      memphis
      killer work man
      Dave
    4. #84
      Chicago
      Quote Originally Posted by ramlinman View Post
      rich
      Thank you for asking but it would be difficult to sell something I do not actually have yet. It's been a pretty long run and I do not have the rear panels , package tray ,kick panels or center console done yet and I'm sure it will be a while before I do. Even when finished they are not a bolt in deal which is what I had originally been shooting for. Speaker options for the original design were very slim and I did not want to get to the end of the project and realise there would be no replacements if one went bad. I then decided to go into the door which requires cutting for clearence. I may consider selling at the end but it's much too early to make promises.
      Tony L
    5. #85
      Chicago
      2 down
      Started on the rear layout
      Tony L
    6. #86
      Chicago
      I cut the rear panel pattern and started the layout for the rear deck.
      Base for the deck.
      Tony L
    7. #87
      Dec 2007
      Carlsbad, Ca
      is there a way to make the panels from thinner, ultra light mdf and cover in glass to reinforce? it just seems that your first product was very useable, with weight being the only downside i could think of. it would still be heavier, but would be much less time consuming.
      will you cover in thin foam and then leather/vinyl/cloth?
      still trying to figure out what im going to do. either marquez if they come out with something, fesler door panels with my dash and rear deck, or everything from me.
      keep up the good work!
      Tim
      Build Thread Link
    8. #88
      Chicago
      The rear panels will be very light. The mdf you see is only to make patterns. I just found out about c70 and will be looking into it . The front panels also have no mdf in them. They are completely sealed and hollow to utilise the air space as speaker enclosures. There is approximately .65 cubic feet of air space in each front panel. Yes the entire interior will be done in black leather. The major reason you see everything vacuum bagged is for weight and strength. The front panels do weigh a bit but the glass for them had to be thicker due to it being used as an enclosure. Sorry for running on I'm typing from my phone.
      Tony L
    9. #89
      Dec 2007
      Carlsbad, Ca
      i guess thats my main question; does everyone use the mdf for the prototype only, or is there a way to use the wood as a final product? they look bitchin as is. if there was a way to just use what you have, your time would end up being 1/10th of what its going to be. your molds are great for multiples, but for one offs it just seems like a lot of work. just trying to figure out what the norm is.
      Tim
      Build Thread Link
    10. #90
      Nov 2009
      illinois
      where in the chicago area are you? i'm up in mchenry county have a 68 ,70 and 72 in progress at the moment. i would like to drop in and see your process first hand
      rich
    11. #91
      Chicago
      Quote Originally Posted by The WidowMaker View Post
      You can use mdf as a final product , lots of stereo installers do, but the panels are VERY heavy. The masters I use to make the mold from are almost completey mdf and probably weigh around 35 to 40 pounds each. I'm talking about the primer gray panels in some of my earlier posts that are mounted to the sheet of aluminum. I 'm not trying to make the car a feather weight but I also don't want to replace door hinge bushings monthly. The rear panels can be made much differently because they will not serve as a speaker enclosure and can be thinner.
      Tony L
    12. #92
      Chicago
      rich
      I'm near O'hare in Chicago . Any chance you have any interior trim parts for sale?
      Tony L
    13. #93
      Chicago
      Smooth progress lately. Made the last backer panel. Made the armrests. And the sub came in.
      Tony L
    14. #94
      Nov 2009
      illinois
      looking good sorry i have nothing for sale right at the moment.
    15. #95
      Dec 2007
      Carlsbad, Ca
      sorry to keep bugging you for advice, but how did you finish the top and sides? how thick does the panel appear when the door is open? what is the correct way to finish off the tops? did you use the stock metal piece and attach your panel to it, or is it all custom?
      i watched a bunch of youtube clips on fiberglassing and making custom panels and i have come up with a few ideas on how to make them light and still incoporate my woodworking "skills". i just dont know how to make it all flow together and finished.
      Tim
      Build Thread Link
    16. #96
      Chicago
      Your not bugging at all. I've been following your car and would be glad to help. The upper half of the panel is 3/4 inch thick give or take. The area toward the middle is about 2 1/2. For the top I disassembled an original door panel and used the original steel upper rail . I bonded the rail to a piece of fiberglass the same shape as the original cardboard with Lord fusor 116. Be careful or what adhesive you use because you are bonding things with completely different expansion rates. Trim the 3/4 mdf below the outer height of the rail (window side). Cover the rail in aluminum duct seal tape and wax. screw the mdf to the fiberglass panel and fill in the top with everglass. Once its filled you can sand it to any shape you like. A few coats of primer, some clear and you are ready to pull a mold off of it. My panel is as thick as it is because I wanted to have a modern thicker door panel look but I also wanted a sealed enclosure. If neither one of these is you goal you can go much thinner. Let me know if I can help.
      Tony L
    17. #97
      Chicago
      Spent some time figuring out how to shape the lower half of the rear panels.
      Tony L
    18. #98
      Chicago
      I should never have said things were going smooth. The Holidays came and crushed my progress. I need to get the sub box sorted out so I can make the rear deck. Once the deck is finished I can finish off the tops of the rear panels. That required getting my air tank . Everything is currently laid in there with a cardboard box to check for clearences.
      Almost all the mud work is done.
      Cardboard mock up sub box
      Tony L
    19. #99
      Feb 2011
      Hills of Anaheim
      Great work! I hate working with fiberglass.
    20. #100
      Nov 2009
      illinois
      how are we doing?
