Results 1 to 20 of 21
Thread: Rear Disc Brake Help
01-08-2007 #1
New to Pro-Touring
- Jan 2006
- 63
Hello,
I am assembling the rear brakes and have a slight problem with the location of the caliper. This is a GM 10 bolt with new moser axles, '79 Trans Am rotors, mid 80's Cadillac calipers and Steeltech brackets. It seems that the caliper is located too far in to fit the outside brake pad. I think I have everything right but I'm not sure.
Please check the pics in the link, they will explain the problem.
Any ideas??
Thanks,
Conno
http://www.cardomain.com/ride/2314745/6
01-08-2007 #2
You may need to use spacers to move the caliper out a little if you haven't tried that already..
01-08-2007 #3
New to Pro-Touring
- Jan 2006
- 63
Where would the spacers go? The caliper doesn't look like it can move out any further, and the bracket is limited by the axle flange.
Thanks,
Conno
01-08-2007 #4
Looking at the photo, looks like the rotor is not slid up onto the axle far enough. Is the inside of the rotor contacting the O.D. of the axle before it's seating against the axle flange? Some axles need to have the O.D.s turned down in order for the rotors to fit correctly.
01-09-2007 #5This is a true statement!! try this also see if you can mount the bracket on the outer part of the axle flange without the same interference.
Originally Posted by yellowrallys
01-09-2007 #6
The Moser axles do not have as long a pilot as the stock axles. Mine also barely protrude out of the rotors. I told them I was using the factory rear dsic setup and my factory brackets line up fine.
There mat be a difference that Moser made for the actual flange distance. I want to think years ago when the Pontiac guys at HO Racing had a kit for A bodies they use a spacer between the bracket and the flange on the tubes.
01-09-2007 #7
New to Pro-Touring
- Jan 2006
- 63
Thanks for the replies, the rotors are snugged up to the face of the axle flange, but I will double check that. I told Moser that I was using T/A disc brakes on them when I ordered the axles.
Also I checked the distance from the face of the axle flange to the face of the axle flange (out to out width) and it is the same as another rear I have in my shed.
I'll try mounting the brackets on the outside of the axle flange, but I think it will hit the rotor.
Does anyone make offset brackets?
Thanks again
01-09-2007 #8
The factory brackets go outside the flange.
