    Results 1 to 20 of 21
      Thanks for the replies, the rotors are snugged up to the face of the axle flange, but I will double check that. I told Moser that I was using T/A disc brakes on them when I ordered the axles.
      Also I checked the distance from the face of the axle flange to the face of the axle flange (out to out width) and it is the same as another rear I have in my shed.
      I'll try mounting the brackets on the outside of the axle flange, but I think it will hit the rotor.
      Does anyone make offset brackets?
      Thanks again
      Jun 2006
      Katy,TX
      The factory brackets go outside the flange.
