Results 1 to 20 of 22
Thread: Runs In Clear! Help!
runs
I usually round both of the sharp corners off the razor blade with some 80 grit, so you don't have worry about digging a trench in the clear. after shaving it down a little ,you can use some 800 grit/w water wraped around a short wood paint stir-stick, to smooth it up, then polish it out. also if your concerned about breaking through, put some masking tape right next to the run ,so your not sanding on the thinner areas. Thats how I fixed the 1 run that I had lol...
