    Results 1 to 20 of 21
      Oct 2009
      Terminator x max
      Regarding the oils pressure sensor on my ls3. The terminator harness plug for that sensor doesnt match.
      Can i just get the bare plug for my sensor and put it on the terminator harness without spending 137$ for the holley sensor?
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Feb 2011
      dallas, tx
      Oct 2009
      Im using stock sensor that came with ls3
      Just changing the plug.
      I have the plug $2.00 from wiring specialties
      LS3
      What is the sensor that comes with the LS3?
      I use ACDelco D1846A and it plugs right into the Holley harness. It does need a custom sensor configuration.
      If I can be of help with the tuning, please let me know.
      Oct 2009
      Thanks andrew yes thats the one that comes stock. This is the oil sensor plug on my terminator
      LS3
      Quote Originally Posted by Sinnister69 View Post
      That connector fits that sensor.
      Oct 2009
      Hmm maybe i didnt try hard enough lol
      But i do know the map sensor plug doesnt fit either
      LS3
      Which map sensor are you using?
      Oct 2009
      Everything is stock
      Is there a gm 1bar that goes into stock ls3 so i dont have to run a vacuum line to the ecm?
      LS3
      Everything is stock
      Holley sells the 558-416. It is a LS1 to LS3 MAP harness adapter.
      Let me know if I can be of service to help with wiring and tuning.
      Oct 2009
      I kinda dont want all these extension harnesses in my wiring. I can just get the plug and replace it
      LS3
      If you got the wiring mojo to do that, then I highly recommend you do that. It is the best option. Be mindful of the pinouts between the ls1 and ls3 map sensors. They are not the same.
      Oct 2009
      Yes thank you
      LS3
      Oct 2009
      Can a MAT sensor be installed where that port is coming out?
      It looks removable
      LS3
      It looks removable
      I generally recommend putting the MAT sensor into the intake tube, ahead of the throttle body.
      Oct 2009
      Will i have to drill into tube is there a good intake system that has MAT provisions
      LS3
      You can drill into the tube and tap it for 1/2" NPT. There is also an alternative sensor that slips into a rubber grommet, so you can make a hole in silicone elbow ahead of the TB.
      Oct 2009
      Thanks i will do that
      Anyone know if you can program a vss into one of the i/o ports?
      LS3
      Yes.
      Oct 2009
      Yes.
      Is there a good link on how to set it up?
      I have a tko 600 and dakota digital guages. I do have the dd holley bim module
      LS3
