    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 53
      Aug 2011
      Connecticut
      My 1967 Firebird (Updates)
      Howdy, been a member for a while just haven't updated in a long time.
      She was originally a 1967 Firebird 326 Auto, well that’s all changed. I started doing some suspension work on it back in 2014 I realized the car was not as solid as it looked. At least not for my liking and the whole scope of the build changed.
      Currently have my car on a chassis jig to replace almost every panel except the skeletal structure and firewall. I’m doing all the work myself so it’s taking a good bit of time but at the end of the day I’ll have built my own car.
      New motor is a 12.5:1 pump gas 408 that is currently under construction. Callies Compstar crank, Callies rods, custom Diamond pistons Texas Speed 2.5 ported 243’s custom camshaft similar to a GM ASA cam, a worked over Edelbrock super victor, Carb and GMPP distributor set up. No major power goals, I’m not trying to break records, I’m just trying to build a very reliable motor for road racing. A few other little trick items in the motor but they dont really do enough to mention.
      Many updates to come
      More pictures and info can be found on my Instagram @NaturalLivingMan
      - - - Updated - - -
      Where I left off before I started the full build.
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
      Aug 2011
      Connecticut
      The tear down began, and its been a slow process because im learning as I go and doing all the work myself.
      This is my mock up motor while the 408ci motor gets built
      New updated thread
      Aug 2011
      Connecticut
      Some actual engine stuff
      New updated thread
      Jul 2013
      It's nice to see a (non-Extreme) Speedtech sub frame. I have also powder coated mine to a similar color (battleship grey). I notice your using the ridetech LCA. Was that decision based the bitchin ridtech shock mount over Speedtechs flat T-bar mount. So, now I'm curious what is your plan for a sway bar. Are the mounts in the same location? Speedtechs sway bar has some of the best clearance iv come across. Ridetechs muscle bar has some clearance issues. A 9.5 rim will hit at about 5.75 back space. Just curious I'm diggin the build.
      Aug 2011
      Connecticut
      Quote Originally Posted by ra11ysport View Post
      My frame is just in epoxy primer right now. I did choose the LCAs based on the lower shock mount. As for a sway bar I will be making my own splined bar with adjustable blades. Essentially used NASCAR or the likes. Im not to concerned about the mounting points since I’m making custom everything.
      New updated thread
      Jul 2013
      I thought about doing that with the sway bar also, but I got the whole package instead.
      I should say I meant the mounts on the LCA's cause you might be able to use the Speedtech high clearance sway bar. If you did use a blade style you could the ridetechs posilinks that would be pretty slick. The one issue I found with a blade style is tire clearance due to the location of sway bar mount on the LCA. Show some pics when you get to it. Thanks!
      Aug 2011
      Connecticut
      You can find angled blades not just straight arms
      New updated thread
      Feb 2012
      I am doing a 68 FB Coupe and need quarters where did yo get yours and were you happy with the quality?
      Aug 2011
      Connecticut
      Quote Originally Posted by hiflyr View Post
      OER was the best I could find for the Firebird quarters. I am very happy with them!
      New updated thread
      Nov 2012
      Colorado
      Looks like great progress, looking foreword to seeing your progress.
      Jeff
      Aug 2011
      Connecticut
      Quote Originally Posted by 32deucecoupe View Post
      Thanks, it’s been apart for almost 5 years now (Burrys head in hands)
      New updated thread
      Jonesboro, Arkansas
      That sway bar is way too cool! I'm going to like this car..
      Carl Wilson
      Mar 2010
      Valencia, CA
      Nice build. It's clear you put alot of thought into it.
      Geno
      Aug 2011
      Connecticut
      Quote Originally Posted by 72blackbird View Post
      Geno
      Thanks Geno, the scope of this project has expanded exponentially from the day I started it.
      New updated thread
      Jul 2013
      Quote Originally Posted by Buryingthesun View Post
      That sway bar is off a purpose built race car. I know you can all sorts of different blades but there's more to it then that. Like mount locations on LCA tire clearance lots of factors go into it. With all that said I can't wait to see what you come up with.
      Aug 2011
      Connecticut
      Got some parts powder coated and I love how they look
      New updated thread
      Aug 2011
      Connecticut
      They fit very well for being modified 4th gen headers
      New updated thread
      Jun 2017
      I'm going to use that same Speedtech non extreme subframe for my 69 Bird.
      Aug 2011
      Connecticut
      Quote Originally Posted by chiva View Post
      I really like the subframe, Speedtech makes fantastic high quality parts! I definitely recommend it
      New updated thread
      Aug 2011
      Connecticut
      Here are some more pictures of everything mocked up for the engine. Im working on building a custom radiator support now for the C&R NASCAR radiator and carbon duct.
      New updated thread
