    View Poll Results: Immediate thoughts???
    Voters
    12. You may not vote on this poll
    • Less Talk More Pictures......
      1 8.33%
    • Take it to the scrap yard....
      0 0%
    • Make it Light Make it Fast!
      10 83.33%
    • This could be interesting.....
      1 8.33%
    Multiple Choice Poll.
    Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 81 to 100 of 125
    1. #81
      Jul 2012
      Mooresville IN
      Quote Originally Posted by Josh@ridetech View Post
      The G-body TruTurn setup has these added corrections:
      - Adjustable cross shafts/different caster slugs for more caster adjustment
      You might want to remove this from the benefits list as the upper control arm is to narrow to allow any slug but the center hole one. The arm does not have enough clearance at frame mount to offset it. I can send pictures if needed.
    2. #82
      Jul 2012
      Mooresville IN
      The past 2 week seem like they just flew by. I've been able to get the 3 link tacked up and some of the rear frame skeleton is coming together.
    3. #83
      Jul 2012
      Mooresville IN
      Boss showed up with his latest toy last week. Trying to talk him into a 10/10ths hpde day.
      Since I do not foresee needing the welding table in the near future we did a little garage reorganizing. Clean garage is happy garage right?
    4. #84
      Jul 2012
      Mooresville IN
      Shouldn't of cleaned the garage or moved #axs10. Had a stranger message me on FB saying he's had 6 different guys tell him I'm
      the guy to fix his car. 22hrs later he has dropped a "bagged" big block Chevelle off for a once over. 30 minutes into inspection it's determined that the shop that did his suspension wanted him to die. Plans were made to ditch the "minitrucker" suspension parts for some well planned ridetech underpinnings.
      Chevelle still fit with the S10 and y daily.
      Tore down ready for reassembly. Decided to go with a disc brake conversion while we we had it apart.
    5. #85
      Oct 2007
      Newark DE
      Quote Originally Posted by BIGMIKE@ridetech View Post
      I lose everything when I clean up
      Truck looks like it is coming along. What are your plans to tie in that rear round tube section, cage?
      That Chevelle looks very familiar but can't place it.
    6. #86
      Jul 2012
      Mooresville IN
      The rear section will tie into the cage as suspected. The Chevelle belongs to a local guy who had been having the car built for the past 6 years. 4 different shops had left him less then satisfied and then he found me. The new ridetech suspension goodies are on along with some wildwood disc brakes and now he has decided to let me upgrade the air management. Here is how the car sits deflated. The 20/22 combo is not my thing but at least we know the suspension and brakes are safe now.
    7. #87
      Jul 2012
      Mooresville IN
      Well, it's been a while since I updated but there has definitely been some progress made on the #AXS10
      Sat a 5.3L and turbo 400 in the chassis with a set of engine mounts from Christopher Kill. Plan was to check stock truck oil pan clearance and see how the cab cleared with the engine in the rear most position on the mounts.
    8. #88
      Jul 2012
      Mooresville IN
      Sat the cab on and bolted it up with a set of solid aluminum JT Raceshop cab mounts. With some floor reconstruction and firewall work the raceseat will fit just right and have room for me to set the engine 6" further rearward than a stock 4.3 would be and still have room for my large build. Also started my first roll cage build.
    9. #89
      Jul 2012
      Mooresville IN
      Was able to finish up the watts link a couple weekends ago also. I'm really starting to love the All Star Performance parts.
      And of course, now it is pushed aside while I set a 3 link and ridetech Coilover system up for a customer. This little tan 82 will also be 5.3 powered but more street truck than the #AXS10.
    10. #90
      Feb 2013
      Looks good, Mike. However...it does appear that your headers are on backwards...
      Please tell me that there are going to be twins on it
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    11. #91
      He's using the exhaust as an air brake?
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
    12. #92
      Feb 2013
      Haha!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    13. #93
      Jul 2012
      Mooresville IN
      Haha!
      What are you doing up at 4:38 in the morning.
      BTW the other S10 rear 3link / panhard turned out ok.
    14. #94
      Feb 2013
      That was 8:28 in the morning. I was still snoring 4 hours before that!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    15. #95
      Jun 2017
      Edgewater Co.
      I'd like to see more of this, I have a '94 S10 Blazer, ( see here. https://www.pro-touring.com/threads/...tine-front-end ) and it's looking like I'll be going with a three link, Did you use the front spring perches for the lower links? BTW tell George in sales that the HQ's in the front were a huge help...
      Joe
    16. #96
      Jul 2012
      Mooresville IN
      Quote Originally Posted by Motoracer838 View Post
      Joe
      Here is a better shot of it. And yes I ran the stock leaf mounts.
    17. #97
      Jun 2017
      Edgewater Co.
      Thanks, that helps. It looks like everybody has those light weight HF jacks, I just bout one because I was tired of dragging my 2 1/2 ton (there are days it feels like it's 2 1/2 tons...) Snap On out to the driveway...
      Joe
    18. #98
      Jul 2012
      Mooresville IN
      Joe
      I have one of the HF Daytona "snap on knockoff" and one of the aluminum. No complaints on either. The aluminum is over 6 years old.
    19. #99
      Apr 2013
      Phoenix, Arizona
      What off set/ back spacing did you use to clear 18x11?!?
    20. #100
      McKinney, TX
      This thing is looking so good man, love it!
      89 Mustang "Box Wine"
