      Jan 2013
      Abbotsford, B.C.
      IAT Sensor install location
      Hey,
      I have a Fast Ez efi multiport kit that I am current installing. On my throttle body I have the port on the rear for the IACV motor and 2 vacuum lines. On the front is the port for the IAT but the sensor from Fast is too big to fit. Can I plug the port on the throttle body and mount this sensor on the underside of the air cleaner? Drill a hole and tap it?
      My understanding the purpose of the IAT is to measure the temperature of the air coming into the throttle body.
      TIA
      Quote Originally Posted by Spork82 View Post
      Hey,
      TIA
      I see no problems with doing that.
      Jan 2013
      Abbotsford, B.C.
      Thanks Andrew!
      Now just need to find the right sized plug for the throttle body.
      Aug 2011
      North Platte,NE
      In a aftermarket setup I would run it as close as possible to TB inlet.
