    Results 1 to 16 of 16
      Oct 2007
      Silly rid tech question
      Got my adjustable coil overs today... Do I need to remove the adjuster to install the upper spring retaining ring?
      67 Camaro In progress
      Oct 2013
      yep
      Oct 2007
      Quote Originally Posted by dragonfly jones View Post
      yep
      Thought so was weird that they didn't come with any instructions and their site has lots of dead ends (bad links Ect)
      Nov 2009
      Austin Texas
      You have to screw the adjuster all the way in and then the perch will slide over it.
      Oct 2007
      Quote Originally Posted by cwylie View Post
      Negative ... Removed the adjuster and I was all set
      Apr 2012
      Woodstock, IL
      The adjustment knob has changed since a couple years ago, you used to be able to thread it all the way in and slip the collar over. Since they've changed to the plastic knob, you turn it in, remove the torx and the plastic knob & you're good to go.
      -Dale
      SchwartzPerformance
      Jun 2014
      braintree essex england
      Country Flag: UK
      did my ridetech shocks last week had to turn to hardest setting then remove screw and knob I felt silly asking ridetech but I was not sore if some thing would pop out under the knob
      Oct 2007
      Quote Originally Posted by KEV 190164 View Post
      I know what you mean... Note to ride tech... Need to get some PDF instructions Ect out on your website for things like this ... For instance is the snap ring supposed to lock in the upper mount or does the retainer just rest up against it...
      Apr 2012
      Woodstock, IL
      It just sits against the clip.
      Fwiw, here's a general instruction in case you haven't seen it.
      This one is old since it doesn't reference the (newer style) plastic knob.
      http://www.ridetech.com/instructions/coilovers/coil-over-instructions.pdf
      -Dale
      SchwartzPerformance
      Oct 2007
      Can you run these without the bearing spacers? Kinda weirded that they come with one set of each spacer not 2 ...
      Des Moines, IA
      Each bearing should have one spacer set and one adapter set, so each shock should come with 8 individual spacer/adapters total.
      One set is a spacer and allows you to use a 5/8" bolt.
      One set is an adapter and allows you to use a 1/2" bolt.
      Both sets are 1.25" wide.
      You do not have to use our spacer/adapters. No matter how you mount them make sure the bearing is free and allows the shock to move. If you bind the mount you'll break the shock.
      I've seen the shocks bolted directly to the frame, so nothing can move. This is not good!
      Oct 2007
      Got it I may have miscounted the pieces I will check shortly! Thank you Britt for the support!
      Central CA USA
      I would bolt the shock up without the spring, set the adjusters to full soft, & run the suspension full travel to check for binding. Pay attention to the shock eye spacers. I had a little binding on the Lateral dynamics three link, no issues on the front.
      Connecticut
      i am confused with this becasue I was able to install my delrin spring washer and upper spring retaining without taking off the knob it slid right over the top and then I used the snap ring to lock it in place.. am I missing something?
      Paul Krol
      1968 Camaro
      Connecticut
      I just looked again and can only assume you are talking about the REAR coilovers? Cuz I have only assembled my fronts so far
      Paul Krol
      1968 Camaro
      Aug 2011
      Connecticut
      I attached a picture of the knob that needs to be removed to install the upper spring perch. This is a newer style ridetech coilover, from the sounds of it the adjusting knob has changed over the years.
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
