    Results 1 to 20 of 21
      Alta Loma,SoCal
      First off..you DO NOT want to use a t3/t4 hybrid on that motor. Way too many cubes for the tiny t3 turbine housing.
      The bigest obstacle to overcome is the 600hp at low boost, and still have an efficient compressor side. I was originally thinking master power t-70, but it isnt quite right at only 10lbs of boost. I need to find my compressor maps for the GT-42, but it looks like it may work great for you. Another turbo that is very common, and should work great for you is the Garrett T-76 with the .96 turbine. That would probably be my choice. I think you could reach you hp goals without having to do a big stroker. The 400 or 455 would be just fine, plus allow for more "normal" sized turbine housings, like a .96 instead of 1.15 or 1.22.
      I would use a FMIC even at 6lbs of boost, but I would suggest around 10-12lbs on a more basic engine(can save a ton of money that way). Buy a good blowoff valve like the Tial for around 225.00. The eclipse isnt very big and will not do the job properly. And for the wastegate remember, big turbo + low boost= larger wastegate needed(you bypass alot more exhaust in this situation).
      1965 Buick Skylark
