Results 1 to 20 of 21
thanx man. I was looking at getting a kit from snow performance. how do they work exactly, do they run open all the time or just when boost hits a certain level?
also what do you think about this cam?
Cam: RPM 2000-6000 DUR @ .050 INT-230 | EXH-230 Lift W/ 1.5 INT-.480 | EXH-.480 LSA110*
now this less valve overlap there is the high the LSA #?
Turbolark, what do you think bout this turbo?
Garrett MasterPower T70
Compressor Trim: .70 A/R
Turbine Trim: .68 A/R
also what would i have to do to modify to carb for blow through?
1979 Trans Am - In the big junkyard in the sky
1980 Turbo Trans Am - In the big junkyard in the sky
A journey of a thousand miles begins with a single BURNOUT!
