    View Poll Results: Should we blow it or gas it?
    Voters
    75. You may not vote on this poll
    • ProCharge it, screw the extra weight, Forced Induction is were it is a must!
      43 57.33%
    • Use the Nitrous, save the weight, Don't worry about it, It's still killer!
      32 42.67%
    Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 21 to 40 of 113
    1. #21
      Nov 2004
      Tinley Park
      also, its different.. pro touring is almost starting to get cookie cutter. forced induction and tt2's are taking over the joint, lol.
      a dual stage fogger setup would be visually intimidating as hell.
      pain is nothing compared to the emptiness that comes from quitting.
      owner of "Primal"
      1970 Camaro RS
      http://www.cardomain.com/ride/2092707
      Camaro Z28
    2. #22
      Cumberland, Maryland
      procharge it and throw some more weight in the back to balance it out...all the sema cars have huge stereos anyhow, right? LOL
    3. #23
      Jackson Ms
      if you want some WOW factor then do a small twin turbo set up. that is really stepping it up and the power will be there too!!!
      Chris V
      SOLD
    4. #24
      NY
      Every high end Pro Tour or Pro anything else these days has high tech type engine. To me nothing beats a regular high hp motor. But as you know at any show everybody is looking for the wow factor.
      I don't care what anybody says these cars are being built for the looks and performance. If you are trying to showcase work go high tech. If you are looking to lay some heavy numbers and impress yourself go with Nitrous motor.
    5. #25
      Mar 2003
      Boringville
      So this car is one big fat write off... ?? Well I would still go with 540, the block shouldn't be much more money, the only thing you would need is the rods and pistons. I think a fogger kit would be cool also. I don't think a procharger looks all that great, I've seen a million of them, looks like a mustang 5.0 with a vortech. Just do a really killer engine bay.
    6. #26
      Rockford Illinois
      What has to be done.....
      From my years of looking at this problem you are having is to break it down into segments of need and reality.
      300hp divided by 80lbs is one heck of a power to weight ratio so going with the charger is great deal of power for the money invested. You don't have to go somewhere to fill it up and if done right the computer can be detuned and retuned to make the power you want when you want it.
      Next on the list is balance. With more power you can add weight to the rear and get it back along with needed traction. With the extra power you have the same power to weight ratio aspect going on again as above.
      As for high speed adventure you will need the extra weight to keep the car having traction and keep it stable. In 1967 LeVan Prothero went to Bonneville and set the record at over 200mph with a big block and a car that had more than 1000lbs more weight in it to add for ballast and traction. You have to compliment power with weight at speed. Remember that top speed is based on drag and overall horsepower and weight has nothing to do with it other than how long it takes to get to top speed and without enough traction the hand of god will hold you back.
      I vote for the Procharger and let it pull it's own weight and use the weight that it has to the advantage instead of looking at it as a disadvantage.
      NOS also has so many problems that arise and blow up motors that it is an invitation to disaster in my book anytime you go with it just to save somewhere else. It has it place and can't be discarded from racing where it helps you out in a class that has rules and stiff competition but for a car like yours I would pass the gas refilling bottle and just turn up the boost to take up the burden of the extra weight.Plus it has been proven time again that by the end of a season the amount of money spent filling a bottle habit can pay for a blower or a turbo in most extreme cases .
      Jim Nilsen
    7. #27
      Jan 2003
      Arizona
      Run the go-juice. Yer outta time!!
      ________________
      Steve Chryssos
    8. #28
      Aug 2003
      Quote Originally Posted by streetfytr68
      Man ain't that the truth. SEMA is tomorrow! I do not like the idea of adding weght to get balance when it is already 3000LBS +. If it was 2500LBS, yeah, maybe. I think since we are losing the nose weight with the aluminum block, we are going for lightweight and balance. 700+HP and 3100LBS it already has power to weight to run bottom 10s (if it hooked) and 200MPH, the hit would push it deep in the 9s and faster top speed then we would drive it.
    9. #29
      Nov 2000
      O-town
      Procharge it, FI it, take it to the track and whip Bulls ass, and then drive it home,
    10. #30
      Jan 2003
      Arizona
      Lots of folks say Procharger--and they're not wrong, but fitting the intercooler can be a real challenge and SEMA really is just around the corner. So Frank and Michael are living through the insanity of a real world "Discovery Channel" deadline. 18 hour high pressure days workdays PLUS suppliers and outside labor dropping the ball PLUS unforseen "do-overs" PLUS time required to haul the car from FLA to Vegas.
      When you get parts for "FREE" you have to live up to commitments. The parts are NEVER free. They are exchanged for exposure. It's gotta roll, stop, steer and fire. If you show up at SEMA with parts, hoses and wires missing and holes where parts are supposed to be, it reflects badly on the car builder. It's just a whole different level of car construction and it sucks.
      So the poll really looks like this:
      What should I do:
      A. Git 'er done: 100%
      B. Screw the pooch: 0%
      ________________
      Steve Chryssos
    11. #31
      Aug 2001
      Your latches should arrive soon....
    12. #32
      Aug 2003
      Quote Originally Posted by Steve68
      Wouldn't that be funny. I already kicked his ass with the pump gas NOS 404 when he had the 14.5 to 1, nitrous injected 468 in it. Now to kick his ass with a ProCharged G machine to his ProCharged 19 X 32 Pro Street car, that would be hilarious! He would be on suicide watch, LOL! He still isn't over the last few races, ROFLMAO!
      Read the CFL board, we just had a favorite win thread, of coarse he is it, LOL!
    13. #33
      Aug 2003
      Quote Originally Posted by Charley Lillard
      Much appreciated sir.
    14. #34
      Rockford Illinois
      No laughing matter but....
      I think you need the laughing gas in more than one way now that it is more clear about the deadline for you. If you don't make it in time someone can at least open the bottle in the room and put an involuntary smile on your face LOL.
      I really don't think that 80 more lbs up front is that negative of a problem. A lot of cars here have it worse than that and some weigh another 200 lbs more. And unless your parked on the scales who is going to know besides you and everyone you tell?
      I have never heard the numbers for the Mule as far as the f/r balance but it sure looks like it is heavier than your problem and noone has ever condemed the Mule for it that I have ever heared.
      So goodluck on meeting your deadline no matter what you decide.
      Jim Nilsen
    15. #35
      Dec 2002
      Lost Wages, Nevada
      ProCharger or no Procharger.............
      Dont you hate playing 'keep up with the Jones' ?
      I can remember ole' Dickeypoo Guldstrand making an excellent point while throwing down some In-n-Out at lunch one day...... "You can make all the horsepower and torque you want, but if you can not hook it up, turn it or stop it..... your a dead man."
      700 is plenty and it always gives you time for other mods later to make more power. You have a deadline and no matter what you show up with, your gonna get the respect you deserve. Even, if you dont have your 'keep up with the Jones' Procharger to make 1khp. With your weight advantage, just late brake them into a turn and keep the transitional mass undercontrol with less effort. You'll beat the 1khp guys everytime....
    16. #36
      Aug 2003
      The deadline is not an issue, were there no matter which way we go. We already have the ProCharger, I am sure I can get the NOS from Holley in no time. Damn all that wiring for progressive, retard, switchs.
      Ugh.
      Maybe N/A? FugIt! If a 700+ HP all alluminum big block in a 3100LB car doesn't do it, to hell with them!
      There, ya like that better?
    17. #37
      Aug 2001
      I do......
    18. #38
      The Netherlands
      Country Flag: Netherlands
      Frank, good to see you came to your senses.....If people see the car they won't miss the extra 300HP IMO
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    19. #39
      Dec 2002
      Lost Wages, Nevada
      Exactly....
    20. #40
      I say a big honkin F3R Procharger!
