    View Poll Results: Should we blow it or gas it?
    Voters
    75. You may not vote on this poll
    • ProCharge it, screw the extra weight, Forced Induction is were it is a must!
      43 57.33%
    • Use the Nitrous, save the weight, Don't worry about it, It's still killer!
      32 42.67%
    Results 61 to 80 of 113
      Aug 2003
      Need opinions, for Project Prodigy
      OK, I need opinions. Long story short, the motor we were going to run in Prodigy was an old motor I had. It never really ran right, so we tore it down. Upon tear down we found some bad news in the block, cylinder wall taper. The rotating assembly is perfect and new, so we are getting a new block. A Bill Mitchell Aluminum block!
      So now we have a 11th hour decision. We can build the motor NA, no ProCharger, and save 225lbs off the nose and a lot of fabrication issues. I could build it 700HP easy and put some laughing gas on it and easily see 1000HP, or ProCharger it and see the same 1000HP.
      Either way it will be fuel injected and all aluminum. My dilemma is it really seems to be a high end PT car, it really needs to be Forced induction. But I hate the bad weight of the intercooler hanging in front of the radiator, that's horrible weight, and the ProCharger hangs off the front of the head, more bad weight. So losing the 225 off the nose will go a LONG ways towards better weight balance. The ProCharger is about 80LBS.
      Realistically, 700HP would be PLENTY, but in a world full of 1000HP cars, it needs to have it. Nitrous is no problem for us, very familiar with it, I can get a fogger for it easy. But does it belong on a PT Car?
      It really was not even a consideration until we ran into the aluminum block deal, and the chance to ditch the extra weight. It will weigh less then an iron / aluminum head small block. Plus Nitrous puts 30LBS in the trunk to help even more balancing things.
      So please vote, and I would really appreciate it if I got some comments from everyone, especially some of you that play with higher end PT cars, you know who you are. I do not want to kill the wow appeal, or value, even though it is not for sale. It still matters.
      Just so you remember. Prodigy is full framed 67 RS / SS Convertible, C4 suspension, Double adjustable QA1s, 14" 6 piston Wilwoods all around, 12" wide 295 / 30 / 19s up front, 14" wide 345 / 25 / 20s out back, TKO 600, 500" all aluminum big block, four C5 buckets, Leather, custom one off dash, full console, power everything, video, navigation, etc. It is really a everything car. So I do not want to cheat it. Also, we do plan to enter it is exhibition of speed events, so it needs to work.
