    Page 10 of 10 FirstFirst ... 5 6 7 8 9 10
    Results 181 to 198 of 198
    1. #181
      Jun 2011
      SoCal
      A little progress on the firewall. Also made some tabs for the tranny crossmember so it will unbolt and drop out from the bottom. Turns out the 4L80 I used for mock up had a different (more shallow) pan on it. The current pan hangs about .5" lower which means the engine had to go forward and up. Will be making the engine crossmember next.
      www.totalcostinvolved.com
    2. #182
      Jun 2017
      Edgewater Co.
      Please sir, may we have some more???
      Joe
    3. #183
      Jun 2011
      SoCal
      Quote Originally Posted by Motoracer838 View Post
      Joe
      No updates worth posting pics of. Mounted the gas tank such that the upward taper imaginary line would match the roll pan(for diffuser purposes). Started wiring up the ridetech ProX, ordered the Intro wheels, & began making new steering arms to work with those badass Billet Wilwood spindles. Ok, maybe I do need to post some pics after all.
    4. #184
      Jun 2011
      SoCal
      Made dual battery trays, mounted the Derale tranny cooler, mounted both compressors & tanks. Wired up the ridetech Pro-X controller so we could cycle the truck at the Brothers Show this past weekend.
      This is Fred, he does all of our brake & air lines on our chassis. He's routing the 1/4" lines from the distribution block to the tanks.
      Threw the fenders, intake and valve covers and stole the wheels off #projectreddawn for the show.
      We received a lot of positive comments. Had a guy comment that the engine will be a pita to work on, so I reached inside, unlatched the doghouse and pulled it out of the way.
      Next stop will be engine mounts, headers, mid pipes, and exhaust.
    5. #185
      Jun 2011
      SoCal
      After the Brothers Truck show we dropped the truck off at Doug's Headers. They built us some easily removable 1.75" primary, mid length headers and 2.5" mid pipes for it. We kept the tubing smaller for better velocity.
      We just started mocking up the Magnaflow 3.5" I/D mufflers yesterday. They will be tight up against the Derale coolers so we'll build a small heat shield there.
      We also began mocking up the Wilwood tandem brake pedal assy. I wanted the pedal as high as possible so we could get the most ratio possible. As it sits we're at about 9:1. The dash will make servicing the master interesting. Will likely make the dash top pin on for easy removal. I'm still not sure what the gas pedal will look like and whether it will be pull or push yet. The throttle body will be rotated 180 degrees from normal so the cable can go right down the valley. The problem is that the valley is behind the pedal. So the cable will have to go back and around the Astrovan cover and up into the valley.
      Once again, I got a little rambunctious and cut the inner roof structure out. The first two pics are dark so it's hard to see but the 3rd pic shows all that was removed. It was worth 30 lbs
      We've had a few different sets of wheels on the truck to get it around the shop. These are some that we borrowed from Schott for another display chassis. They're 18's & 20's with way too tall of a tire so it doesn't lay frame with them.
    6. #186
      Jun 2017
      Edgewater Co.
      Joe
    7. #187
      Jun 2011
      SoCal
      Not really an update so much as a video version of the pics above.
      https://www.youtube.com/watch?v=mXK5LLlNq-w&t=
    8. #188
      Nov 2016
      Sulphur, La
      Is there a version of this "chart" with the shock mounts that are on the normal kit ?
      Quote Originally Posted by Sales-TCI-Eng View Post
      Ed was working on shock placement while Sal and I were at SEMA. Here is what he came up with. This is basically our original upper shock mount raised another 7/16". She's going to be loooooooooooooooooooowwwwww.
    9. #189
      Jun 2011
      SoCal
      Quote Originally Posted by CSG View Post
      Our standard shock mount would add roughly 5/8" to the dimensions above in the right column. The standard front end can go really low, so much so that we're currently in development of a raised spindle. All of the info on this chart has changed since then. The truck now has 5.1 travel shocks on it and an even taller upper mount. We have a couple different versions of the upper mount right now but will likely have another as we develop a full chassis based on this truck and a stepped rail.
    10. #190
      Nov 2016
      Sulphur, La
      I assume the stepped rail chassis will require the bed floor to be raised?
    11. #191
      Jun 2011
      SoCal
      Yes, the bed was raised 6" on ctwin. Not sure yet if that's where we'll end up on the production piece though. There is a possibility of an IRS that will allow us to retain the stock frame rail profile and yet still go real low.
    12. #192
      Aug 2022
      Is this project stalled? So much custom, I need more build!!
      Archie
      ’59 F100- CV/S550, Who knows where it’ll end up????
      ’73 FJ40 LS/SM465 35’s Puts a smile on face
      ‘07 Sienna - Takes me to the parts store more often then id like to admit.
    13. #193
      Jun 2011
      SoCal
      Quote Originally Posted by Archies Beater View Post
      I have taken Rob MacGregor's advice and began simplifying the build to just get it out there. The truck isn't gaining any marketing exposure collecting dust. We ditched the turbos (luckily the shortblock isn't built yet), 4L80, and sleeve portion of the airbags (keeping the ridetech triples of course). I am also going to back down off the ledge of chopping the roof and a few other body mods.
      Next on the agenda is to get our new Pro-Touring chassis underneath the truck. Don't worry, the engine set back will remain since there's no going back on the cab now.
      So technically, the truck needs a new name since "Ctwin" doesn't work anymore.
      New plan consists of going with a more off the shelf approach: "Keeping it simple"
      New TCI Pro-Touring chassis
      TKX 5 speed
      Build the 416" but with more compression & cam than previously planned
      Put coil springs on the ridetech Triples we already have
      Maybe add some lightweight body components up front
    14. #194
      Jan 2024
      Gainesville, Ga
      TKX 5 speed
      I read this whole thread...it's like a bench racing session with my buddies except you actually did it all lol
    15. #195
      Jun 2011
      SoCal
      Quote Originally Posted by TotallyHucked View Post
      HAHA, and you've gone and made me log in for the first time in forever.
      I tried to finish the truck in my spare time but just felt overwhelmed with the process. George Reiss from Reiss Racing bought the truck from Ed and will complete it with the turbos and hopefully our new Pro-Touring Chassis. Last time I saw the truck it was in primer. A long way to go still but but at least it's in capable hands.
      -Jason
    16. #196
      Nov 2021
      Omaha, NE
      Such a great build thread, and I am familiar with letting a project take much longer than it probably should. My 1964 Chevy C20 named STEEVE took me 8 years because I put 6 other projects ahead of STEEVE. Do you have any further updates on the build since a year and half ago?
      Additionally, I like the part where you stated you decided NOT to chop the top! Not that my opinion matters on other people's builds, I just don't like the chopped look on trucks. It just does not look visually correct (proportionally).
      I am currently researching how I want to go about building my newly acquired 1978 Chevy C10 BIG10 named Big Ted. I think I know the route I want to go on it, but still in the planning phase, but I will be autocrossing and road course racing with it.
      1964 Chevy C20 Restoratmod (STEEVE)
      1973 Firebird Formula (Fool's Gold)
      1978 Chevy C10 BIG10 (Big Ted)
      2024 Chevy 1500 3.0L Duramax (Jack)
    17. #197
      Jun 2011
      SoCal
      Quote Originally Posted by Raszaron View Post
      Like you, other projects have gotten in the way of this one. George picked up a Blazer to build for an autocross bruiser. We have both driven #TCIequipped Blazers and we feel it is the cheat code to going fast. They are better balanced and just get out of a corner better than anything else (even without the top on). Ctwin will live on eventually, more than likely as a very capable street truck that gets raced occasionally. -Jason
    18. #198
      Nov 2021
      Omaha, NE
      Ah, yes, the Blazers... I've seen some videos (ok, a lot of videos) of the trucks and Blazers out there running. It made me want to build a Blazer (so I could also haul the entire family around on cruises!). Unfortunately (for me anyway) the prices on a clean Blazer are quite steep now, and for one that is moderately built even higher! I got into the 78 at a pretty good entry price and it doesn't need much in the way of body work (plus I don't want to ruin the patina!)
      My biggest dilemma right now is figuring out if I should build my 73 Pontiac Firebird Formula (already purchased 85% of what I need to start a Pro Touring build) as it is a completely rust free chassis (the only problem is a spun bearing in the Pontiac 400). Or build the 78 C10 BIG10 (of which I haven't purchased anything for it yet but replaced the waterpump just so I could drive it.
      I've thought about just selling the Pontiac and taking that money and getting one of your Pro Touring Chassis for the 78 C10.
      But I would probably kick myself for selling the Pontiac in about two weeks after doing that!
