    Page 6 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
    Results 101 to 120 of 198
    1. #101
      Jun 2011
      SoCal
      Quote Originally Posted by gator68428 View Post
      Really??? What are you guys planning??? Something with E85 and 800+ horsepower?
      I'll let the cat out of the bag in the next few days.
      I heard you've got 315's up front now. You've gotta send me some updated pics of your car in action.
      -J
      www.totalcostinvolved.com
    2. #102
      Huntington Beach, CA
      Cool that you are taking this over Jason! When is the show you are targeting?
    3. #103
      Jun 2011
      SoCal
      Quote Originally Posted by Chad-1stGen View Post
      In 10 days. Hoping to have it back to a rolling chassis by then.
    4. #104
      Jun 2011
      SoCal
      The Holley Hi-Ram is in our possession now so we can actually do some mock up with the coils. There is plenty room to mount them underneath it. We just want to make sure that they are serviceable somewhat easily. Probably make a one piece removable shaft so they come out as a unit.
      Some more major components have arrived. We haven't done a bagged shop project in a few years so this is kinda exciting. ridetech triple adjustable shockwaves 5" travel front and 6" travel rear. Dual 3 gallon tanks, dual pumps and their pressure based ride control system.
    5. #105
      Mar 2015
      FL
      The high ram is gonna be sweet. Nice work on the custom coil mounting--good use of space.
      Quote Originally Posted by Sales-TCI-Eng View Post
      -J
      Check your facebook messages, I sent you some pics--to the TCI Engineering fb messaging.
      -Mitch
      G8 GXP, White Hot, Auto, bone stock
      68 Firebird, 428 Pontiac, CNC'd KRE Al d-ports, hyd roller, EFI, TKO600, TCI Eng complete chassis, Ridetech, Kore3 C6Z brakes, C5Z 18" with 315 rivals x4, C6zr1 mufflers
      RRR, NASA HPDE https://youtu.be/DPp1l9-FuNE
    6. #106
      Aug 2011
      Sevierville, TN
      I always wondered if that setup would work underneath the Holley or the Edelbrock intakes. I never got to find out on my own since I'm carbureted. I'm looking forward to a final product to see how you did it. The only major concern would be too much heat.
      Matt Kenner
      68 C10 stepside
      If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower. - Mark Donohue
    7. #107
      Jun 2011
      SoCal
      Thanks Mitch, I'll repost them very soon. What's your IG name?
      Quote Originally Posted by Slick68 View Post
      I've spoke with a few engine builders and the consensus is that it's just as hot on the valve cover by the exhaust. Not as much ventilation though.
    8. #108
      Feb 2013
      South Carolina
      We make those injectors. There's a 163 lb/hr version available...
    9. #109
      Jun 2011
      SoCal
      Quote Originally Posted by JustJohn View Post
      Good to know. I'll see how far these take us on E85 @ 80% d/c. Definitely won't be as far as the rest of the package will allow.
    10. #110
      Jun 2011
      SoCal
      So the thing about boost. It's just a measurement of restriction. Less restriction, more flow at a given pressure. On a naturally aspirated LQ4 these 230cc AFR heads would be overkill. I've already said too much. Those that know me, know the direction this is headed.
      -J
    11. #111
      Socal, Ca
      i bet Jason isn't going turbo... They couldn't get skrapes iat in check while racing with a turbo... Vortech...?
    12. #112
      Jun 2011
      SoCal
      Quote Originally Posted by DJW32 View Post
      Skrape never datalogged IAT's on track. His engine compartment lacked the room to properly build a CAI. He also lacked the grill space for a properly sized FMIC. I wouldn't doubt his IAT's were approaching 200 on a 100 degree day simply because the turbo inlet was pulling 150 degree temps out of the engine compartment.
      There would be little difference in IAT's between a centrifugal blower and a turbo if the compressor wheels were the same and both were pulling ambient air into the inlet.
      I guess I just defended myself into letting the cat out of the bag. hehe
      -J
    13. #113
      Feb 2010
      El Segundo, CA
      -J
      Put the radiator in front of the tailgate and just have a big intercooler where the radiator used to be. 8^)
      G
    14. #114
      Jun 2011
      SoCal
      Quote Originally Posted by Dr G View Post
      G
      The C10 has plenty grill space to fit even the biggest A2A. I bet one of Gale Banks' diesel FMIC would fit. Plus, this truck will be a work truck first so having a usable bed is a must.
      -J
    15. #115
      Feb 2013
      Let us know if you need anything!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    16. #116
      Feb 2010
      El Segundo, CA
      -J
      I give myself the same criteria - usable bed. I "think" one could put a radiator in front of a (vented) tailgate and still have the bed be usable in some way. Though obviously the tailgate could no longer go down.
      One thing I am against is stacking an air-to-air intercooler in front of (or behind) a radiator. God forbid there is also an oil cooler and/or AC condenser in the stack. The unit at the tail end of the stack gets blasted with hot air, and the reduced air flow due to all the restriction just hampers efficiency too much for my taste. My goal is to mount all air-cooled heat exchangers in unique locations with their own dedicated flow of air.
    17. #117
      Jun 2011
      SoCal
      I've owned quite a few heavily modified turbo cars over the years. The only issue I've ever encountered with a large FMIC is higher A/C pressures. I even had a front mounted A2A that was converted to A2W so there was literally no air going thru it. The core blocked half the radiator and it never had any cooling issues.
      The '72 C10 grill has an upper and lower grill opening each with 162 sq/in. The core support opening is 420 sq/in. I will build ducting forcing air from the grill to the core support opening based on whatever I/C design I go with.
      I will attack this one of two ways. I am generalizing core sizes in order to explain the difference.
      #1 Use a 6" thick I/C core that is roughly half the height of the core support opening(7.5"). That way half of the radiator is getting clean air from the grill, the other half has 6" of I/C core obstruction.
      #2 Use a 3" thick I/C core that is the full height of the core support opening (15"). The radiator isn't getting clean air at all but there is only 3" of I/C core obstruction.
      I will likely end up with something in between these two. There are other cooling considerations as well, tranny, power steering, brakes and of course A/C. There will be some trial and error with it all. After the issues we've had with #projectReddawn I also have concerns about too much air entering. We installed Track Spec motorsports vents in the hood to alleviate high speed lift.
      -J
    18. #118
      Socal, Ca
      -J
      I assumed boost was going to be used...I didn't know which one. I hear that tall intake will hurt numbers down low, but kick butt on the top end.
    19. #119
      Jun 2011
      SoCal
      Let's be honest. This thing is going to light the tires up at will. We've purposely moved the power curve to the right with those heads and intake. We'll also gear it tall to try to make it somewhat drivable on the smaller courses. Even on wastegate spring it's going to be a handful.
      I am most excited about getting out to some half mile events, turning it up and letting it eat.
      -J
    20. #120
      Socal, Ca
      I may have missed it, but what trans are you using?
