View Full Version : Brake line pressures
Skip Fix
06-27-2011, 08:54 AM
What is "normal" pressure when you are on the pedal for a manual system?
Current system for drag car 79 Camaro manual Vette deep recess 1" MC pedal in "top" hole 6.71 ratio. Front brakes 10.75 rotor Wilwood Dynalites 4 1.75 pistons. Hurst Line loc used as the T for the fronts and the port for the pressure gauge. Rear 79-81 WS6 TA 11.125 rotors with 2.5 piston "metric" front calipers(no ratcheting E brake calipers). Old Mopar adjustable prop valve in line-pressure port after that.
Car not running brake system all new just rolling in garage setting it all up.Bled the crap out of it, bench, gravity and pressure bleeder.Inner and outer Wilwood bleeders and bleeder on pressure gauge.
Problem has been alot of pedal travel to me, and a fairly easy soft pedal. Do see pads work and stops hand spinning front wheel. May need a larger MC since pretty big rear pistons.
Got the rear pressure gauge hooked up-didn't have enough line for the other one. With the prop valve all the way open less pedal feel but gets 550 psi at the bottom of travel holds it. Prop valve all the way decreased 400, a little better feel but still soft. Takes 3" of the 5-6" travel to even get 200 psi.Drops quickly with letting off pedal just a little. Seems a little low to me but never used a gauge before.
More line on the way to hook fronts up.
So anyone used a pressure gauge?
I know there is a 1 1/8 Vette MC. There also is the generic aftermarket 1 1/16 Mopar style that needs the bolt spacing massaged. At one time I saw a guy using a manual quick take up S-10 MC but it had a shallow rod recess.
wmhjr
06-27-2011, 09:58 AM
My wilwood gauge only goes to 1500psi. My Wilwood brakes (7/8" master) give me 1400psi with a little effort on the front, and about 1100 on the rear. I could be wrong, but even 550psi just ain't even close to being enough.
Skip Fix
06-27-2011, 10:02 AM
So what to look at MC not generating pressure?
06-27-2011, 12:42 PM
I'd expect to see 1300psi on the front on a 70's single piston front caliper.
Your 1 3/4" front calipers are a little small, should be closer to 1 7/8" or 1 15/16".
Skip Fix
06-27-2011, 02:10 PM
David thanks for answering-most the Wilwood setups that use the Dynalites have the four 1.75 pistons on them. I think that is the largest for that caliper. They have been the standard four piston Wilwood front caliper in a drag or street kit until recently and are on their 12.18 kits also. I think just year they developed a Superlite caliper upgrade for their kits that has a larger pad and pistons that Frank and some of the others started carrying.
I was expecting to be seeing over 1000psi also. The 6' of line I got for both lines only made it to one running from drivers to passenger side where I had to mount the gauges to see them.More teflon line on the way by Wednesday to plumb the fronts to see where it is.
By the way I love old vintage road race cars like Lolas- I think I even have and old HO electric one somewhere. Made it to Laguna also when I was buying some Herb Adams stuff at the old shop on Cannery Row in '79-80.
Skip Fix
06-27-2011, 02:50 PM
My math I get 9.62 sq In per front caliper and 4.9 on the rear calipers a side.
Factory 2 15/16 single piston 6.73 sq in.
So larger Sq in than even the factory 4WD that used a 1 1/8 MC.
rrunner68
06-27-2011, 04:14 PM
Without knowing the amount of force you are pushing onto the pedal, its not very helpful to say you have XXXpsi at the pedal. For example, at 100psi input, I should see around 700 at the caliper. Its the M/C bore to piston ratio multiplied by your pedal ratio and psi of input at the pedal.
wmhjr
06-27-2011, 05:30 PM
I assumed the numbers were psi at the caliper. That's what mine were.
rrunner68
06-27-2011, 05:35 PM
You are correct, I mis-typed that line.
"Without knowing the amount of force you are pushing onto the pedal, its not very helpful to say you have XXXpsi at the *caliper*."
Skip Fix
06-28-2011, 07:12 AM
Since I don't have a calibrated leg hard to tell what leg force has been a few years since I powerlifted and squatted 380 lbs as a 148.75 lber.The 500 psi was stomped as hard as I can at the bottom of travel and pumped the pedal a few times and the max pressure I could generate.
I would assume the pressure in line past the prop valve should be the same line pressure at the caliper since there are no restrictions to the caliper from there. So how do you plumb a gauge at the caliper-use the bleeder hole and T it so you can still bleed the gauge? Or T the supply line to the caliper?
wmhjr
06-28-2011, 07:45 AM
I removed the bleeder and screw in the wilwood gauge. Pretty simple even for me.
Skip Fix
06-28-2011, 08:33 AM
These are dual gauges set up to be used while running for changing brake bias on the run.
http://www.summitracing.com/parts/LNG-44136/
They now have some smaller ones that would have been an easier fit in the dash.
Since many calipers have different bleeder threads(heck my 78 TA the factory rear wheel cylinders were different than the replacement ones) does it come with a bunch of adapters? Still have a bleed to get the air out from under the gauge?
Apogee
06-28-2011, 09:09 AM
Front Caliper Effective Piston Area = 4.80 sq inches w/ 10.75 inch diameter rotor
Rear Caliper Effective Piston Area = 4.90 sq inches w/ 11.125 inch diameter rotor
Aside from the obvious mismatch front to rear with the calipers combined with the fact that the front rotors are smaller than the rears, the pressure issue should strictly be a function of the input force, pedal ratio and master cylinder bore size. Brake torque will take the caliper piston areas, effective moment arm of the rotor and the pad coefficient of friction, but that's not what you're asking if I'm not mistaken.
You mentioned that you were running the 2.5" piston diameter, metric front calipers from presumably a G-body or 3rd-gen F-body, which may be a large part of the pedal travel issue you're having. The 1978+ metric calipers are a low-drag caliper design intended to be used with a quick take-up master cylinder. That combined with any air in the system could definitely lead to a pedal like you described. Did you confirm that your master cylinder was fully bench bleed? Given your MC bore size and output pressures, I would expect your pedal to be high and firm...I think that I would lean towards a smaller bore MC to get your pressures up and a quick take-up design to deal with the volume issues introduced by your rear calipers. There are alternative ways to constrain your pushrod if needed.
Tobin
KORE3
Skip Fix
06-28-2011, 12:17 PM
Tobin thanks. The math in the front is still off to my brain. Four 1.75 pistons. pi x r x r x 4.3.1416 x .875 x .875 =2.405 x 4= 9.6. Or do you just use one side of the multiple pistons?
The factory TA 4WD used a 2 15/16 front with an "11" rotor that was a hair smaller and a the 11/.125 rear rotor and a 2.5 rear caliper. 79-80 had a cast iron non quick take up MC and 81 used the aluminum quick take up 1 1/8. With their dual diaphragm booster they used even less ratio than the regular power disc brake pedal ratio that was 3.91.
Right now just trying to diagnose the poor pedal feel, Bench bled util no bubbles. Pressure bled all 4 corners multiple times. Currently have Wilwoods BP-10 pads on front and some old new organic Bendix on the rear. The car will have skinnies on the front and a 9 or 10" slick on the rear. Estimate 3500lbs and guessing a 53%+ front bias on the weight.
Apogee
06-28-2011, 03:40 PM
Skip, your PM Inbox is full.
You're correct that you only use half the number of pistons for the effective area calculation when looking at a fixed mount caliper. I know that it is counterintuitive, but just go with it. As for the master cylinder, no more bubbles doesn't necessarily mean no more air inside...just no more air coming out. I always plug both outlet ports and push on the piston to confirm that there is no more air hiding in the MC. A fully bleed MC will hydraulically lock after about 1/8" of piston travel, just enough for the seals to clear the compensator ports to the reservoirs.
Tobin
KORE3
Skip Fix
06-29-2011, 05:46 AM
Thanks again Tobin. So how would you get more air out if you've bench bled and pressure bled already?
I might get some plugs and give it a try. I still think it is a MC issue either a bad one or air in there. With air I would expect the pressure reading to be all over the place and not as consistent.
"You're correct that you only use half the number of pistons for the effective area calculation when looking at a fixed mount caliper." Seems then like a fixed caliper shouldn't work as well as floating then to cram pistons in.
http://www.wilwood.com/Calipers/CaliperList.aspx?subname=D154 Single and Dual Piston Floater
Here are the Wilwood dual piston calipers that would swap on the rear. Might have to look at the dual 1.12 ones. But heck that is almost 3/4 the price of a Dynalite rear set up, but I'd have to pull the axles out to get the caliper bracket off.
John Wright
06-29-2011, 05:52 AM
What Tobin is saying that sometimes the air gets trapped...it might just moved back and forth and not actually get bled out with the fluid as you pump the MC.....so while bench bleeding, run lots of fluid out of it until you can get it to hydra-lock.
opnwide
06-29-2011, 11:17 AM
I think the 1" MC is marginal for this system. The 4 disc TAs came with 1 1/8" bore MCs. I've got the s-10 rear disc conversion (off a 2000 extreme) on my trans am, and I still have quite a bit of travel, even with the proper MC. A rebuilt MC from Autozone will run you $25. Give it a try. The 1981 version is a little more pricey, but has a plastic reservoir and looks like the MCs from the 1980-1990s. I cannot lock up my brakes (crappy pads and not much vaccuum assist) but the car stops well enough.
Skip Fix
06-29-2011, 12:12 PM
So MC questions(still waiting for UPS to make the front line) on the Vette and most GM masters there is a 1/2" and a 9/16 fitting which is front or rear? Does is matter if both reservoirs are the same size-ie do the internal pistons do any metering? The Vette as well as an extra 81 TA MC have the smaller one in the rear. My TAs are over at the stirgae space across town. The 81 also looks like the reservoirs are pretty close in size
Second question I do have a Strange 1 1/16 MC new I could try. The reservoirs are very different sizes-to me unusual for one that is used on race cars with 4WD and ususally the same front and rear calipers.So on my setup which should get the larger reservoir? The 81 TA 1 1/8 has a pretty shallow hole to keep the pushrod in, the Strange isn't real deep like the Vette ones are. But heck the manual 67 GTO MC I bought hardly has a recess either.
Greg you know Steve Coombs over there in Austin?
Skip Fix
06-29-2011, 03:52 PM
UPS came, got the line done, and have 1050psi on the front when I stomp on it hard-150lbs+ leg pressure. Rear is still only around 550 max. Both go to 400(a little past the acel pedal) at the same rate and numbers then the front I have plumbed to the front larger port leaves the rear in pressure untgil the very last stomp does it move off 400 to 550. I would not think the adjustable prop valve would cut it down that much. With a disc drum and the same prop valve I had it balanced pretty good for autocrossing. So MC stil not generating 1400 psi(max on the gauge).
So could it be the big rear pistons are taking so much volume on the small bore MC it can't build full pressure like it can on the front? A QT MC on the rear?
I guess I can try the line loc now and see if it holds pressure.
Greg I was drilling teeth yesterday, just a small mouth than you are used to a 6.5 lb cat.
Skip Fix
06-30-2011, 09:44 AM
Dustin at Wilwood said pressures aren't that off for the calipers, not sure why the rear is reduced unless the MC has some internal metering.Theri MC do not but some factory ones do. Suggested a larger to get less travel but may be at the expense of leg effort.
So with a long weekend looks like I wil be trying a few things out in the heat of the garage. Might try swapping front and rear ports and see if the one port still is putting out less pressure
Skip Fix
07-01-2011, 04:46 AM
From Wilwood's site on their master
CALCULATING EFFECTIVE PISTON BORE AREA TO DETERMINE PLUMBING
To determine the effective piston bore area of any caliper, you must first calculate the area for each piston bore found on one
side of the caliper. Use the formula " Area = (bore x bore) x .785" for each piston bore size. Then, add the areas of all pistons
on that one side of the caliper to determine the total effective piston bore area. Compare the difference between the front and
rear calipers and attach the line from the primary outlet "A" to the calipers at the end of the vehicle with the greater total
So where do they get the .785? I though area sq in was pi(3.1416) x r x r with r being 1/2 bore
Their masters do have different volumes for the different ports so maybe that is the issue with mine.
silver69camaro
07-01-2011, 08:39 AM
0.785 is pi/4. They just rearranged the equation.
Skip Fix
07-01-2011, 11:46 AM
Matt thanks I see that now that you point it out,any thoughts on the ordeal here?
In looking at Wilwood's site their MC do have the same pressure but also one end only moves half the volume. I would assume the Vette one does also. Maybe why the rear isn't building the pressure the front is.
Skip Fix
07-02-2011, 05:51 AM
From Strange's site on their MCs Mopar style so pressures in the ball park for lockup but reversed. Still alot of travel to get.
PEDAL / HANDLE RATIO
1.032” bore master cylinder: Pedal ratio- 5.5 to 1 / Handle ratio- 11 to 1
1.125” bore master cylinder: Pedal ratio- 6.5 to 1 / Handle ratio- 13 to 1
The 1.032” master cylinder is recommended for systems using single piston or two piston calipers up front, and four
piston calipers in the rear.The 1.125” master cylinder is used with four piston calipers in both the front and rear. Brake
pressure should always be checked with a brake pressure gauge before use. In disc brake applications used for drag
racing only, front brake pressure should be 550 to 650 lbs. and rear brake pressure 1,000 to 1,100 lbs.These pressures
should be achieved with a lot of effort since they are at “lock-up”of the tires and the actual normal stopping pressures
will be lower.
Question for you all if most of these aftermarket MC have a 2:1 volume output difference why have the same size reservoir? And if pistonsizes are the same(4 piston front and rear liek many aftermarket and early Vette) does it matter if the small is on the front or rear?
andrewb70
07-02-2011, 08:09 AM
will be lower.
I wouldn't pay much attention to what is said on the Strange website because the majority of their customers are drag racing. ON a drag car the rear brakes do a lot more work than the front brakes because the rear tires are massive and the front are puny.
For a car that is set up for handling and overall performance you want more brake pressure in the front. I did a pressure test with my system, you can read the results here:
https://www.pro-touring.com/showthread.php?40904-1970-GTO-Version-2.0/page10 Post #189
I am using a 15/16" bore MC. My set-up at the wheels is not slightly different, but not much. I used to have the Wilwood billet superlite 6 calipers with 14" rotors on the front. I now have the C6 Z06 brakes which also use a 14" rotor and the caliper piston area is very similar. I've never measured the pressure at the rear, but my prop valve is fully open and the rear brakes don't lock up before the fronts. However, the rear braking system uses a smallish C4 single piston caliper and a 12" rotor. Eventually I want to swap to the matching C6 Z06 set-up from Kore3.
Skip Fix
07-02-2011, 09:50 AM
Andrew thanks for the input-on disclaimer this car is for the time being(my project swap duties) going to be mainly a drag car, but most of the drag guys if it stops well enough to make the last turnaround that is OK,so maybe not the ideal for their car. I think the folks here have a better handle on brake stuff. Dustin at Wilwood did also say the pressure weren't that bad.
So you have a fixed caliper on the front(so only use 1/2 the sq in) and a small floating on the rear. The C4 rear is much smaller than the 2.5" metrics I have so they need a little less volume to move. No reason why a GOOD 1"(just a hair bigger than the 15/16" you have) shouldn't have made over 1000psi with as much effort as I used to the Wilwoods on the front. There is nothing for a restriction but the line loc acting as a T for the front brakes and the port for the pressure gauge.
Most of the master seem to use the larger 9/16 port as the "secondary" port-I assume the rears. That is how this MC is plumbed right now,it is on the rear port. An extra 81 TA 4WD master I have has the larger on the front port, as do most of Wilwoods, but the front reservoir is slightly smaller so I assume that it the rear(although I think I have my 78 with an 81 MC plumbed that as the rear and it is well balanced).
My biggest issue is the excessive travel with little effort to get low pressure, with alot of effort at full travel you only get moderate pressures. So with little effort and alot of travel seems like needs a bigger MC. The low drag calipers may be the biggest fly in the ointment also, and may need to be swapped out-heck maybe the actual ratchet E brake TA calipers might do better.
Skip Fix
07-05-2011, 02:54 PM
Well swapped the front for the rear lines at the MC and removed the prop valve-pain finding all the right fittings on a weekend. Too hot to bleed it out (99 degrees) over the weekend so will try later this week-got too much air in it doing it. The Strange MC I have is 1 1/8 and has a very small reservoir for the secondary port, that is going on next as a trial if this MC looks good just too much travel.
Skip Fix
07-06-2011, 03:15 PM
OK for you brake experts-new data for you. Took completely out the prop valve. Plumbed rear brakes(2.5" Gm metric calipers 11" rotor) to the "front" brake port of the GM 1" Vette MC. Plumbed front Wilwood 4 piston 1.75"Dynalite to the "rear" port. 6.7:1 pedal ratio.
Previous alot of pedal travel,little effort fronts would develop 1000psi , rears 500 at full pedal alot of leg pressure. Both would got to 400 at the same rate then the front would keep climbing.
Doing some research some of the early GM MC had about a 60:40 output front/rear. All the Wilwood tandems have 2:1 output volume their new aluminum or their Chrysler aluminum.
So after swapping the lines, gravity bleeding and pressure bleeding all 4 corners and both gauges the rear now goes to 850 and front 800.But both slowly drop 100-150 psi. Pedal is better as far as effort but still takes almost all the travel to build that psi.
I'm still thinking especially now since the pressure slowly drops it's a bad MC.
andrewb70
07-07-2011, 06:55 PM
If the pressure is dropping the MC is bad or the linkage is overcentering and loosing leverage.
Skip Fix
07-08-2011, 07:40 AM
Andrew it is dropping with the pedal near the floor and not moving my foot. Going to swap on a Strange MC I have laying around this weekend to see what I get and will keep you all posted.
I'll probably use the "front" for the rear bigger piston calipers. All else fails may have to swap on some of the new Wilwood D154s with the small dual pistons.
Skip Fix
07-20-2011, 05:48 PM
Update for you all. Put on the Strange 1.125" MC after bench bleeding the crap out of it. Got hard when plugged like it should Tobin. Had to make a new pedal rod out of a long 3/8 fine thread bolt. The Stange rod has a rubber sleeve in a groove to help retain it but the hole is 3/4" deep, so I would think pretty deep. I guess I can have a friend chuch the rod in a lathe and cut a groove.
Pressures both go up the same and go up to 1100 stomped hard near the floor. 200 comes real quick with maybe 2-2.5" of travel. Definitely a firm pedal and less travel than the bad 1" was. Definitely alot firmer and more effort than my power brakes on the GTO I just drove to dinner(fajita night:) ) So not sure if another good 1" would still be too easy and too much travel to move the volume of fluid to start building pressure or if a 1 1/16 would be the ideal ticket. I guess a slight decrease in pedal ratio would move the piston more per pedal travel as well as give better feel for the 1", but that involves pulling the pedal out and drilling it between the upper and lower power stud.
So any of you with a pressure guage what is it reading while actuall stopping and engaging the brakes? I want to think the Wilwood guy said around 400 or so is generally operating pressure.
I haven't added the ajustable prop valve back in yet, not sure I need it with skinnies on the front and big tires on the rear. I do have the rear plumbed to the rear, which probably moves 1/2 the volume as the front port if it is like the Wilwood "Mopar" style. Not sure if the bigger low drag rears would do better with more volume.
Skip Fix
07-25-2011, 06:17 AM
New update for you all. Plumbed the adjustable prop valve back in the rear. No drop in pressure when wide open-so it wasn't an issue before. Cuts pressure almost in half when all the way shut.
Skip Fix
07-25-2011, 12:16 PM
Also some numbers from another guy with a gauge.
"Sitting still - 200 PSI
Regular stops - 400-700 PSI
Staged, 1500 rpm - 800 to 1100 PSI (depending on light/dark, etc)
Absolutely to-the-floor, both feet on the pedal and standing up in the car - 1450 PSI"
