    Results 1 to 20 of 22
      Kiler wisconson
      Project JUST-N-SANE is back up and running!
      4 days of hard work... compeletly hand assembled engine and installed short block into car and finished assembly from there..
      So far soo good... Im only running 10psi for now with my current 9.0-1 compression untill it is well broken in.(around 600hp). Hopefully this winter i will change to a 4.5 inch pulley to get 15 psi (680-720hp)
      Well... here is the start - finish pics..
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
