    Results 1 to 20 of 22
      Kiler wisconson
      Quote Originally Posted by strangler
      Thats a lot of power for a 2 bolt block isnt it? It looks like you have main studs, but still.... What rpm do you expect to spin it to?
      You would be surprised what a stock block can handle... ive heard stories of guys with over 750hp with stock block..
      Acording to ATI a stock block with ARP bolts is good up to 800HP.... after that you need a good aftermarket block..
      Im spinning my engine at a max rpm of 7000..
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
