    Page 24 of 29 FirstFirst ... 14 19 20 21 22 23 24 25 26 27 28 29 LastLast
    Results 461 to 480 of 578
    Thread: 69 GTO Build
    1. #461
      Jun 2012
      N. Shore, Ma
      Sd7
      Great news the GTO is finished!
      Just kidding, Happy April Fools Day!
      Have only had a small break in between jobs that pay the bills to get some work done.
      Was able to Cad up a Sanden SD7 compressor and drop it in my assembly to test fit with the custom motor mounts.
Size:  138.4 KBName:  IMG_4652.JPG
      Happy with the minimum 3/4" clearance, so I picked up a set of Dirty Dingo mounts. They are made well and have the 3 positions to work with the different belt offsets.
Size:  112.0 KBName:  IMG_4659.JPG
      Had to cut and re-weld lower bracket to move tensioner away from steering rack fitting.
Size:  120.6 KBName:  IMG_5070A.jpg
      Eric
      Building 1969 GTO - Roadster Shop chassis, LQ9 w LS3 heads and rebuild parts from TSP, Bowler prepped Magnum T56 6 spd, 3 Link Strange 9" w Speedway Floater Hubs, Wilwood 14" F - 13" R brakes, 275.18 - 345.19
      https://www.pro-touring.com/threads/94970-69-GTO-Build
    2. #462
      Fire it up!!!
    3. #463
      Jun 2012
      N. Shore, Ma
      Hey Andrew, Would love to hear it fire up soon, its been so frustrating having it so close to turning the key. Next I need to research then grab an engine harness, LS3 intake, throttle body, injectors and have the ECM programmed.
      I have been looking at this harness.
      https://www.psiconversion.com/produc.../HAR-1093.html
      Eric
    4. #464
      Quote Originally Posted by ekmxryda View Post
      My buddy Brian used a PSI harness, and no complaints. However, there is nothing like being in charge of your own tuning. He has since converted to a Holley Dominator system. You can use a HP...or if you want DWB, do the Dominator. If you are starting from scratch, the HP is really not that much more money. You will just have to get a 4 bolt cable TB.
    5. #465
      Jun 2012
      N. Shore, Ma
      Wiper Motor
      Was able to finish up the bracket for mounting the new Wiper Motor (ACDELCO 88958170) today, its these little things that take forever!
      Combined the new splined wiper arm with the old one so it will work with the stock wiper mechanism.
      Some better shots of the AC compressor.
      Eric
    6. #466
      Does that wiper motor have "park?"
    7. #467
      Jun 2012
      N. Shore, Ma
      Hi Andrew, Yes it has a park feature, going to need to go junkyard shopping for the harness and switch. Probably should have just bought the kit from Detroit Speed!
      On the harness and ECM I would love to learn how to do some tuning with the Holley system someday.
      I'll keep it in mind when I am shopping this spring.
      Eric
    8. #468
      Nov 2016
      Inspirational! Looking amazing
    9. #469
      Feb 2013
      Ft Worth, TX
      Are you sure it has park? I think that style of motor needs a parking mechanism on the arm because the rotation axis of the motor can't shift like the original motor did. That how it works on the 4th gen Camaro motor in my Chevelle.
      1970 Chevelle: 6.0 L96, T56, Strange 9 Inch, Ridetech Coilovers, Wilwood brakes
      1978 Firebird: 6.0 LQ4, T56
      2007 Sierra 2500HD LBZ
    10. #470
      Jun 2012
      N. Shore, Ma
      Hi David,
      I had an article bookmarked on my computer that just quit a while ago. I could be mistaken but I thought it had an internal feature to know where park was, its been a long time since I read the article.
      Will look and see if I can find it again. Maybe someone with better wiper knowledge can let me know.
      Here is the same wiper motor running, without the big park cam on the Camaros and Monte Carlos.
      PN 88958170
      BUICK LESABRE 2000-2005
      OLDSMOBILE AURORA 2001-2003
      PONTIAC BONNEVILLE 2000-2005
      https://www.youtube.com/watch?v=KPFL13Bj65E
      Eric
    11. #471
      Feb 2013
      Ft Worth, TX
      Unless I'm missing something, there's no way for that motor to park the wipers. The original motor worked by moving the shaft which pulled the wipers down. The park cam on the newer motors works by shortening the lever arm which also pulls the wipers down. The Camaro motor runs backwards for about a quarter turn after the wipers are shut off which causes the cam to collapse itself.
    12. #472
      Jun 2012
      N. Shore, Ma
      Hi David, I think you are talking about the recessed park feature? Yeah I will have to figure that out later, sorry for any confusion. Its on my to do list just down near the bottom.
      Eric
    13. #473
      Feb 2013
      Ft Worth, TX
      Oh sorry, I figured that's what Andrew had asked about. If you end up wanting to add recessed park let me know and I'll get you some more detailed pictures.
    14. #474
      Jun 2012
      N. Shore, Ma
      Wiper info
      Yah any picts of your setup would be cool, I think I just need the wiper linkage between the arms and wiper motor.
      Found this one on RockAuto
      Eric
    15. #475
      Jun 2012
      N. Shore, Ma
      Refurbished 12200411 Drive By Cable GM PCM
      Have only been able to get to the GTO once in a while, not much to report.
      Working on laying out gauges and components using the 69 Impala dash that needed three inches sectioned out of it width wise.
      Picked up a 411 drive by cable computer from BP Automotive.
      Thinking about mounting it under dash, in console right in front of shifter on top of trans tunnel, will make sure to insulate (both sides) really well to keep it from getting too hot, plus I plan on leaving an inch or more for an air gap below it. Could always mount a computer fan behind it too.
      https://bp-automotive.com/
      Eric
    16. #476
      Jun 2012
      N. Shore, Ma
      Sparco Seats
      Still working on interior, trying to get the dash layout where I like it and figured I need the seats and new steering wheel to get the layout right.
      Name:  GTO 8-17-4.jpg
Size:  36.0 KBName:  GTO 8-17-6.jpg
      NRG quick release
      Name:  GTO 8-17-1.jpg
Size:  30.3 KBName:  GTO 8-17-5.jpg
      Very happy with the new harness from PSI, great customer service and everything looks to be made well.
      Name:  GTO 8-17-2.jpg
Size:  29.2 KBName:  GTO 8-17-3.jpg
      Eric
    17. #477
      Jun 2012
      N. Shore, Ma
      Exhaust
      Bought a 3" 409 Stainless exhaust kit from Mandrel Bending Solutions.
      SpinTech 300 Series Mufflers, was looking at side exit but it will be easier to get an inspection sticker out the back.
      http://mandrelbendingsolutions.com/b...9-ss-expanded/
      http://spintechmufflers.com/split-case-300-muffler-180/
      Name:  GTO 10-17-1.jpg
Size:  158.0 KBName:  GTO 10-17-2.jpg
      Eric
    18. #478
      Dec 2010
      Charlestown NH
      Any updates!?
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    19. #479
      Jun 2012
      N. Shore, Ma
      Happy 4th!
      Hey thanks for checking in, not much for major updates, same old story working too much! Although I have been buying parts.
      Finished layout on dash, need to buy gauges next.
      Mad Electrical Trunk mount battery kit.
      http://www.madelectrical.com/index.shtml
      Ring Brothers stuff is nice!
      Eric
    20. #480
      Fire it up!!!
    Tags for this Thread
