      Jul 2001
      Detroit, Michigan
      Power Steering hookup advice....
      OK....so you guys who transplanted LS1's into your 1st Gen F-bodies, how did you hook up your powersteering pump to the power steering box? I've heard this can be a bit tricky.
      I need a list of parts (with part numbers) and a brief instruction, if you would be so kind.
      Thank you gentlemen.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
      Mountain Springs, Texas
      Post number 3 should get you there:
      http://ls1tech.com/forums/conversion...-adapters.html
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Pensacola, FL
      A few ways to do it. I bought complete cars (98-02 Fbodies) for my swaps. I used the stock lines & had them modified at a local shop. The return is easy- just buy the amount of hose you need & have it crimped to the old return fitting. Fot the pressure line, I cut the LS1 hard line just before the crimped hose. Used the metal portion of my old fitting from the steering box & had the shop assemble everything. You could have one made from scratch using reg high pressure hose or braided hose. What does your setup consist of? Scott
      IN/MI border
      Hey Tony, what box are you running? I just went through this.... throw me a PM or give me a shout 989-205-4002 cell.
      Jul 2001
      Detroit, Michigan
      Thanks guys. It's a '68 Camaro with retro-fitted LS1, stock power steering box.
      Buddy, I'll drop you a line tonight?
      Project: Next Year
      Nov 2011
      Glendale, AZ
      I got my adapters from Dirty Dingo in Arizona. Fairly reasonable, uses a common belt, and is billet aluminum.
      Aug 2001
      Connecticut
      I had similar issues, some good ideas were posted here.
      https://www.pro-touring.com/showthre...itting-problem
      I used the DSE fitting and was able to keep the DSE hoses that were on their steering box from my old gen1 motor.
      -Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
