    Page 8 of 15 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
    Results 141 to 160 of 288
      San Bernardino, CA
      i chickened out on going to the bone yard today for a set of drums. by the time i rebuild them and buy some ranger 5 lug drums ill be into the brakes for about as much as the discs cost. i found an old post on stangnet that shows how to cut the stock sn95 bracket and install it on a fox axle. it looks like the previous owner cut the brackets and installed them sorta correct. im sure i could space it out correctly if i play around with it. if not some $160 north racecars brackets may be in order. Im only missing dust shields. I have calipers, pads, rotors, and brake lines. I was thinking of running a fox body mustang hand brake along with sn95 rear parking cables if i stick to the sn95 discs.
      aside from the rear end i have started stripping some of the body panels with my grinder and a paint stripping wheel. I found out that the car has two paint jobs and healthy coat of 2k primer. the thickness takes away from the lines of the car. I will be ordering some epoxy primer (spi), u-pol raptor bed liner, and some rage gold filler soon. For now the door and trunk lid i stripped are waring a very light coat of rattle can primer.
      I also discovered that i can run the stock mustang shifter! all i need to make it work is the shift linkage from a Nova.
      here is a pic of the layers of paint.
      San Bernardino, CA
      I now have a full functional emergency brake set up using the existing 67 mustang drum brake cables. I fabricated some brackets out of 1/8 flat stock and attached them using one of the caliper bolts. I had to make a bracket and weld it to my crossmember for the equalizer rod. I can lock the rear wheels with just 2 clicks of the brake handle. works flawlessly!
      San Bernardino, CA
      man stripping paint is a real pain. i broke my grinder and had to get a new one. I attacked the trunk deck tonight with a paint stripping wheel, aircraft remover, and 40 grit on an electric orbital sander.
      this paint is invincible! while i was letting the grinder cool off i would go at it with sand paper. didnt get very far before it got dark out.
      found a skim coat of bondo on the drivers side. the bare metal parts of the panel feel smooth and i havnt found a single dent or ding yet. the yellow primer that was covering the panel was some tough stuff to get through.
      San Bernardino, CA
      just like the trunk deck the doors had just as many layers of paint. after removing it all the metal is slick, virtually dent free, and not scratched at all. why they used so much bondo, primer, paint is beyond me.
      i picked up some dura blocks and a gallon of rage gold. i still need some epoxy primer, high build primer, and some slick sand poly. my driver side quarter has some dings in it and my roof also has dings. i dont think i need to slick sand the entire car. the doors are proof that a regular 2k will get the job done.
      McKinney, TX
      Taking it down to bare metal is a wise move.
      89 Mustang "Box Wine"
      San Bernardino, CA
      seriously! i found bondo directly over the factory gold paint. the bondo that was on bare steel had zero sand scratches.
      Mar 2013
      Beaufort,SC
      Nice project keep up the good work
      Feb 2011
      Indpls, IN
      I've been using Matrix paint products on my Falcon. I'm new to paint and bodywork, but happy with the results so far. And cheaper then PPG Deltron except for the Basecoat.
      Used Evercoat Rage extreme filler and their tow part finish filler.
      Try the 3M Roloc wheels. The Green ones. I used them on parts of my car after getting tired of paint stripper. Kinda wish I used them the whole time. Except for the dust all over my garage. They also have bigger ones for a angle grinder.
      San Bernardino, CA
      Quote Originally Posted by Jetfixr320 View Post
      thanks for the tip. i have been using poly carbide abrasive wheels on my 4.5" grinder and 2''on my die grinder. they tear through the bondo easily but kinda mar up the metal at bit when you really dig in.
      here is a before and after of my trunk lid.
      the leopard spots look worse in the photo than they really are. I used chemical stripper to take down the blue/purple/grey paint. then DA sanded the rest down to the factory red oxide primer. from there i coated it in paint stripper and scrubbed it clean using a scotch bright pad. i will go over it again with 80 grit in a DA before i primer it. The trunk deck is now sleeping in my parents spare bed room.
      Feb 2011
      Indpls, IN
      Before I tried the 3M Rolocs, I was using paint stripper from Lowes to get through two layers of paint, but it wouldn't do much to the factory red primer. I used 80G on a DA to remove the primer.
      The Rolocs go through all of it. And not worse then 80g on the steel.
      Used a varied selection of sanders and wheels to get into the tight radius of doors and jams.
      San Bernardino, CA
      Not much to update on. Ive been an ebay junky lately. Ive purchased all the rare early 67 manual steering parts need to switch over from power. I found out my 67 steering box has the spear of death long shaft and a unique 1" sector shaft like the 65/66 cars used. My year used a unique manual pitman arm. I scored a manual long shaft gear box with pitman from ebay along with a new manual idler and original manual center link. Also scored a master body bolt kit for about 1/2 retail price.
      I labored away today and stripped one of the fenders to metal. It had the same amount of unecessary filler and layers of paint. I used my electric orbital sander with 60 and 40 paper to blast through the layers of paint. I will most likely hang the fenders and door before I do my filler work.
      I also found out I cannot run the truck alternator bracket. It put the alternator up about an inch above the finder. Lol. I'm going to buy an F body style low alternator only bracket and idler setup from LSbrackets. Bummer it's $150 but it's spaced out correctly for the truck crank and around the same price for used F body parts on eBay.
      More pics to come soon.
      Jan 2009
      Chattanooga, TN
      Just went through all the same crap with early year 67 long shaft box. I replaced the drag link and inner and outer tie rods a few years back. Just recently realized my pitman arm ball joint is a huge contributor to slop in the wheel. I had just assumed it was wear in the gear mesh. Went through a minor ordeal to source a replacement and now it's tighter but sticks. The steering will "pop" and suddenly make a small turn in or out on corner entry and exit. Seriously annoying and maybe a little dangerous.
      I know you just bought all the stuff, but it's honestly one of the worst combos of parts you can keep on these cars! It's unsafe, worn out, hard to find good replacements for, and near impossible to find new stuff. I don't mean to be a Debby downer, but swap to the rag joint later year style, swap the column and get all new stuff if you really want to stick with manual. Or for about less than double that cost say screw it and get a manual rack. This is just my opinion from somebody that wishes they didn't have that system!!
      Stephen S.
      1967 Ford Mustang 4.7L, T5
      Apr 2010
      PHX, AZ
      Amen. Terrible, terrible system. Ford really did like to make things difficult for hot rodders.
      San Bernardino, CA
      its been months since i have touched the car. Found out my girlfriend was pregnant a few months back and have been spending alllllllll of my money fixing things around the house and getting ready for the baby.
      i have since put the car on hold. in the meantime i have added over 500sqft of concrete to my backyard and side of house, added new electrical fixtures and ceiling fans, installed new laminate floors, trim, and paint in the kids room, and bought a crib and dresser.
      hope that keeps her happy for a while!
      i did score some cheap ls1 water pump spacers so i can run the ls1 pump with a truck crank pulley. they have a drilled fitting to run the steam like into them.
      McKinney, TX
      Congrats on the upcoming baby! They tend to put less important things (car hobbies) on hold.
      San Bernardino, CA
      Feeling very left out lately I decided to order a few parts for the car. I have a new 6.0 style truck flexplate coming in the mail. It includes the flexplate, crank spacer, and bolts all for $65 new. It cost less then the gm spacer and bolts! It will allow me to run a th400 converter with the 11.5 bolt spacing without any modifications. Aside from that I'm going to hit up the junk yard for a 2000+ v6 mustang master cylinder and I need to score the drive shaft companion flange for my 8.8 rear. I have an old th400 drive shaft in my garage from my 69 camaro about 10 years ago. Pretty sure the shaft is too short for my mustang tho, but the u joints are new and the slip yolk is correct for the th400.
      San Bernardino, CA
      got the flexplate in the mail today
      How does the stock starter engage the flexplate with the spacer?
      San Bernardino, CA
      no difference. when you use a flat flex plate like above the spacer goes directly on the crank. with a stock ls1 of 5.3 curved flex plate the spacer goes on after the flex plate. the spacer provides support for the converter hub. if you lay a flat flex plate with the spacer next to a curved one the starter ring gear is at the same height.
      i opted to go this route because the curved flex plates are set up for the smaller 10.75 th350 torque converter bolt circle and require ovaling the holes to make the converter bolt up. this is a direct bolt on for a large bolt circle th400 converter.
      im looking at a mild 2500 stall 10'' converter from jegs.
      Quote Originally Posted by DCx View Post
      Gotcha...so the flex plate is specifically designed to keep the ring gear at the same plane...
