Results 1 to 20 of 35
07-07-2005 #1
Speed Tech Lower Control Arm Clearance Problems
Hey guys,
Just got my lower Speed Tech control arms after a 3 1/2 month wait and runaround. (That is another story). If they would not have had my money already I would have just used my original lower arms. Got the new uppers and lowers installed, attatched the spindle and installed the new Baer rotor and calipers(very nice stuff). Everything looked good until I jacked the lower arm up to my old ride height. And that is not very low at all, 13 1/4" center of spindle to fender lip. I would like to go lower eventually. The lower ball joint ring that the tubes are welded into just makes contact with the rotor. That ring extends down beneath the ball joint assy approx. an inch but it is still in line with the tubes which makes me leary about grinding any material from it. As I lower the wheel the angle of the ring starts to align with the rotor and clearance increases. As I raise the wheel the angle increases sharply and the lower edge of the ring quickly contacts the rotor. Lowering the wheel an inch gave me a full 1/4" clearance. So would I need a 1/4" for every inch travel the other way also? Or more? I am wondering if I could clearance that ring without weakening the arm? Looks like that would give me the clearance but would it make the arm weak? Any advice would be appreciated. I tried to take a couple of pictures of the ring and of the clearance issue. One other thing I noticed was my wheel has moved out some. Gonna need some more backspacing and new wheels. Thanks guys.
Dave
