Results 21 to 40 of 42
Thread: Mercedes engine conversion
07-07-2011 #21
Pro-Touring Veteran
- Aug 2004
- NY
- 1,070
Look for a salvage 500e and swap everything over. There was someone in CT posting on EBAY. You then get everything in one stop deal even the wider body parts. Heck for about $10k you get a complete good car. LS will be $8k with used parts and you still dealing with suspension and rear.
$15-18 are realistic numbers for a done car that will have value.
LS will fit. Any V8 should fit just use simple tubular crossmember.
07-08-2011 #22
- Dec 2007
- 59
It looks like you can get 275s under the rear with the flared e500 fenders, if that is the case, then yes, I am in. This will save me a lot of headaches, thanks. I'm not seeing anything different, geometry wise, between the rear suspension on an E500 and the other Es, except bigger sway bars, so I think I am fine. Oh yea, and the differential is an issue, so I am down to that issue.
07-16-2011 #23
- Jan 2008
- 33
the best option for keeping the mercedes rear suspension is to swap in a late GTO diff and 2-piece driveshaft. The diff and driveshaft have the same design as the benz. It shouldnt take much work to mount the diff and the driveshaft could be shortened or lengthened as needed. Custom half-shafts can be purchased from Mark Williams Enterprises.
Here is a diff on ebay:
http://cgi.ebay.com/ebaymotors/2004-...item256519cab7
07-16-2011 #24
