    Results 1 to 20 of 42
      Dec 2007
      Thanks for the tip on the GTO diff, that is a great solution and cheap. I downloaded all wiring diagrams and found several owners that were disabling the ASR. So once you disable ASR you can run a mechanical posi setup. There is a guy doing an 1993 400SEL build on LS1tech, looking good so far:
      http://www.ls1tech.com/forums/conver...l-ls-swap.html
      My guess is that you will have to disable ASR, SLS, and most likely the ABS. The computer systems are a detachable designs with the ability to (probably) jumper out the systems and therefore disable easily with having to reprogram stuff. Here is a link to the ASR defeat. About halfway down the page under "performance.."
      For now, I am fixing my SLS and driving it until winter....I will build an engine stand for the LY6/4l80E combo in the meantime and get it fired up.
      http://www.2phast.com/500e/
