    Results 1 to 20 of 42
      don't ditch the ABS! it will stand alone. Also, Mercedes did us all a favor and made most of the brake components interchangeable with other models. Look in the brake section of the 190rev.net site. Your wagon may already have big brakes...take measurements and see if the rotors are the same as a 1992-3 400E. If not, look for calipers and rotors from a 400E or 500E from those years. slotted and drilled replacement rotors are available. There are threads on that site that show you what parts you need. Direct replacement S.S. brake lines are available too (Summit racing has em). Your stock master cylinder will be good to go.
