Results 21 to 40 of 44
Thread: High vs low RPM
Lee, I have to say that I'd love to get into a conversation with you over this and a couple of beers. There's a lot you said I agree with, and a good bit that I strongly disagree with. There are advantages and disadvantages to both small and big blocks - considering that you're also leaving out a whole lot of blocks. To use the 409 as an example is defective from the start. The 409 was a relative unique situation, and the entire combustion chamber difference is enough to keep it out of this contrast.
IMHO, forget about the block in your analysis, Lee. Think about the rotating assembly and the induction system and valve train. These days, big blocks and long rod motors can easily be built to spin fast - but the real point is how quickly the motor accelerates. Not just where the torque is. I've got a "harley type" motor as an example. It's a 113" long rod motor with both the bore and stroke a good big larger than "stock". Now normally that means it would be even more "torkey" but would have issues in the whole "increase rpm over time" equation. However, the superb R&R heads in that S&S case allow the motor to rev REALLY quick - through it's rpm range. Now, the entire Evo V-Twin design is obviously limited in terms of RPM range, so while it gets there real quick, there is only so far to go. I'm not running that motor past 6500, and peak torque is at around 4800 - though it's still pulling hard through 6500. The correct analogy in car engines for the whole tq vs rpm debate would be better shown by a F430 vs a 427 or something. The debate there is NOT the block design. It's the rotating assembly and valvetrain. There is IMHO far too little difference between a BBC and a SBC for the debate to be very accurate these days in this regard.
For the OP, the real question is what do you want to do with the car, how much, what are you willing to spend, and how much time are you willing to devote. The question why wouldn't 600hp at 4000rpm be as good as 600rpm at 8000rpm is again easily explained by us motorcycle guys. The working RPM range, when larger, allows for more flexibility in gearing and speed. But that's assuming you're making relatively equal amounts of torque through most of the power band, which is difficult to do. Otherwise, you're simply adjusting your gearing to take advantage of whichever design you have. At that point, weight and reliability become the largest factors.
But for the OP, let's keep it simple. If your car will be mostly driven on the street, building tq from idle up is simpy wonderful. There is nothing like being in 5th (overdrive in a TKO600) and being able to simply press the gas pedal a bit to increase speed up a hill and pass somebody. And, the motor is not being pushed - and I'm using less fuel. OTOH, if it's mainly a track car (I'm talking road and not drag) then a lighter motor helps with weight distribution. Don't forget though that I'm betting I'll go far longer between rebuilds as I'm making over 550lbs tq pretty much ALL of the time - through my entire rpm range - meaning I won't have to hammer my motor quite as much as somebody running for example a large displacement SBC. And I've got more material in my cylinder walls, etc.
This debate will never get resolved. It can't be. Too many variables. But I'm thinking that just for this debate, LS is pretty hard to beat.
'66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
