      No. Nevada
      348 block is cracked, time for a new plan!
      I had been gathering parts to build a nice 383" 450 HP, 7000 rpm "W" Chevrolet from a 348 block to go in my '59 El Camino.
      Turns out the block has a water-jacket crack.
      Could be pinned and used, for a stock build, but not mine.
      So now I need a new plan.
      I have a fresh unfired STOCK (except for the Zero deck and balancing) 454 on the engine stand.
      Not going to get many RPM out of that, it's also heavy, and BIG.
      I Also have a good 350 4-bolt block sitting around.
      I know LS engines are the big deal now, but I'm trying to keep a semblance of vintage feel to this car.
      SB Chevy is a LOT less expensive to build than a 348 or 409 "W", even with trick parts.
      Want 450+ HP and decent torque, would like to get fairly decent mileage.
      I also have a weakness for engines that rev high.
      Probably contradictory desires here.
      I have the 350 block, the '59 will weigh in at around 4000 pounds.
      Desired cruise speed is around 100 - 120, would like to top out a bit higher.
      Built a 350, 383 other?
      At these prices I want my gas 100 octane, leaded, and my windshield washed!
      Mantorville, MN
      Scrounge another 348 block... W-engines are way cool, and the only engine that really looks "right" between the fenders of a winged Chevy.
      Derek Kiefer,
      Mantorville, MN
      Pensacola, FL
      sell everything & go LSx. Ok I'm a little biased, but everything you just described in what you like in an engine= LSx
      Scott
      Mar 2010
      AZ
      Keep the originality and build a BIG cube W engine.
      Robert R.
      1988 S10 blazer 5.0L SBC 700R4 body off build.
      1991 S10 Blazer 4.3L too low daily.
      1975 Cutlass Salon currenlty 350/th350
      Stupidity should be painful.
      So. Cal
      I vote for the new all aluminum 409 from World Products. That is my next engine build.
      By the way, you going to sell that 348 block? I need one for a display.
      Shaun
      No. Nevada
      I expect so.
      But just the bare block, the rest of the parts will be used on another.
