    Results 1 to 13 of 13
      Apr 2010
      Windshield Mount Rear View Mirror with Compass
      Anyone know of a vehicle that has one of these? I'd like to get an auto-dimming mirror that mounts to the windshield and has an internal compass. I'm guessing the wire would run up through the windshield molding and back down the A-pillar. Preferably something under $50.
      San Antonio, Tx
      4th gen camaro, 02+ GM trucks, impalas, most buicks and caddys.
      Instagram: CamaroAJ
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by CamaroAJ View Post
      lights only on the 4th gen mirror unless there was an option at the end or the run I'm unaware of. I put one in my 77.
      Scott from NJ.
      Vent Windows Forever! ...
      NY
      Quote Originally Posted by BonzoHansen View Post
      Ditto! My late '02 SS has map lights only, no auto dim.
      Apr 2010
      Sweet, thanks. Do you know if the memory for the garage door openers, if they have it, is inside the mirror itself or is it connected to an external ECU?
      Also, a company called GENTEX apparently makes these and is a popular vendor for them in other communities.
      San Antonio, Tx
      depends on the car, if the buttons are in the mirror then its all in there. most of GM's garage door buttons are in the sun visor though.
      Instagram: CamaroAJ
      Pensacola, FL
      Hit the salvage yards and look around. I have a 4th gen mirror in my 67. I hope to use a 07-up GM truck mirror in my 69, but not sure whats involved with their wiring.
      Scott
      Jan 2009
      Spartanburg,SC
      most infiniti's and nissan upper scale cars have the auto dimming feature, i put one from an infiniti i35 in mine but the garage feature is also in the visor. i have looked at it and it would be pretty simple to retro into your visor if you are going to recover it.
      Richard Parker
      2nd Gen. F-Body Lover
      My 99 Tahoe has the auto dim compass and temp in it. I don't know if it needs an ECU to work?
      Nov 2004
      Colorado
      Look up Gentex mirrors on ebay plenty of sellers. Just paid $150 for a brand new one with auto-dim map lights and compass. Came with harness, sensor and the wire to turn the map lights on with the dome light.
      Feb 2007
      USA, TN
      Quote Originally Posted by EFI69Cam View Post
      Do you have pics of your install? I'm looking at one of these. I ran multiple wires to the mirror area of the headliner when I wired it, so connecting should be easy.
      Nov 2004
      Colorado
      Quote Originally Posted by TnBlkC230WZ View Post
      I have only run the harness, it runs up the a pillar under the cover, then behind the windlace and comes out of the hole in the sunvisor holder where the original mirror's "arm" came out. The mirror will be mounted about 3-4" below there. I've held the mirror up with the harness plugged in and it looks factory.
      No pictures yet, sorry.
      Phoenix, AZ
      +1 on the Nissan/Infiniti route. You can find mirrors with the garge door opener, compass, ambient temp display, and auto-dimming mirrors for pretty cheap. If you want the ambien display, be sure to get the temp sensor (usually located in front of the radiator).
