    Results 1 to 20 of 21
      Rod end experts -- got a question
      I'm looking for a 1/4" or 3/8" rod end that is rated for rotational use. It needs to support 100 rpm or so, though that's just for peak usage. Normal usage is much slower.
      Anybody got any ideas or contacts?
      thanks!
      jp
      ​John Parsons
      san diego
      There is a chinese company that makes a high speed rod end. It has a ball race around the outside. But you have to order a lot. the only other solution is to use a bronze bushing (oilite) and replace over time.
      san diego
      http://www.zhbearing.com/en/cp-1.asp
      This is the only place I could find this style of bearings. I needed one for a project at work and ended up going another direction because I couldnt not opbtain these.
      Looks promising, but are these rated for rotation? I guess that's why they use roller bearings...
      ​John Parsons
      I just found these (thanks for the hint Bryce) at McMaster. Though they don't say rated for rotational use.
      Oh: and they cost $100.
      jp
      ​John Parsons
      Rustburg, Virginia
      Are you building a steam engine?....LOL
      No, lol!
      It's for wiper motor linkage for Unfair.
      ​John Parsons
      san diego
      jp
      I guess you can include another Engineer on your build HAHA!
      Oct 2009
      Modesto
      www.applied industrial.com and contact the local service center.
      Oct 2005
      Odessa mo.
      Try here they supply alot of the racers with ends they may be able to help you outhttp://rodendsupply.com/
      san diego
      rod end supply sponsors my buddies trophy truck. Great rodends!
      Thanks guys. I checked it out. No ball-bearing versions. I'll bet they can get them, but I doubt they can offer them in a less expensive version.
      jp
      ​John Parsons
      Rustburg, Virginia
      Still looking for that connecting rod to use on your steam engine?...LOL
      Just curious, how much articulation(swivel) will this rod end require?...and will it be in only one plane?
      I'm picturing a situation where the motor and the linkage are not in a perfect parallel plane, hence the need for some articulation in the rod end.
      Quote Originally Posted by John (Isaac Newton) Wright
      Exactly. We've got a wiper motor bolted to sheet metal moving linkage that moves in an arc also bolted to sheet metal. So we need some "forgiveness", plus the ability to support full rotation for hours at 100 rpm.
      However, the crappy stuff GM used (steel ball with stamped steel socket, held together with rivets) has us thinking we may be over-engineering.
      jp
      ​John Parsons
      Nov 2007
      Lafayette, LA, USA
      There is not really much load so not just try a regular or teflon lined unit and see how long it lasts. The factory just uses a nylon bushing in that application so I don't know why a rod end would fail?
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
      Rustburg, Virginia
      Quote Originally Posted by fordsbyjay View Post
      The car is in Fla, so it isn't like he will be worried about heavy, wet snow loads on the wipers blades....LOL
      Go on JP....DUIT....find some factory linkage that is the right length and git-r-dun.
      Jan 2009
      Jacksonville Florida
      I haven't used wipers in Florida for couple years on my Supra and drive it everyday,rain or shine, I don't even see why you guys need wipers . Hurricane rescue vehicle?
      Do what's right,not what's easy
      69 Firebird
      71 Cuda
      98 Supra 6speed white APU
      98 Lexus GS400tt widebody
      Elite Custom Body
      Stefan B.
      Quote Originally Posted by Stefan
      Damn right. 200 mph, 8s, road racing hurricane rescue vehicle. LOL!
      Seriously, we want to offer our solution as a kit for sale. It will need to support heavy, wet snow, hours of heavy rain, and other nasty weather scenarios in order for us to offer the kit in good faith. That's why I'm on the prowl for an elegant and sturdy solution.
      jp
      ​John Parsons
      May 2001
      Mesa, Az.
      Should be cool. Can't wait to see what you guys come up with.
      Phillip
      Batesville, IN
      Just brainstorming, but could you use a ball and socket in combination with a rotational bearing?
      I've always wanted to incorporate some of this stuff into a project.
      http://www.igus.com/default.asp?C=US&L=en
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
