    Results 1 to 20 of 24
    Thread: Clampless
      Nov 2009
      Clampless
      Has anyone used theres.
      http://www.jegs.com/p/Gates/Gates-Po...43359/10002/-1
      They look good nice and clean
      64 Mercury Comet
      408w boosted
      More boost on the way!
      Aug 2005
      Hamilton, NJ
      Rupp has them on Bad Penny. Look great. Downside appears to be a somewhat expensive tool needed to remove them w/o damaging the hose. I've also heard of longer term failures.
      Scott from NJ.
      Vent Windows Forever! ...
      Nov 2009
      k i think i might keep the hose clamps
      64 Mercury Comet
      408w boosted
      san diego
      Looks interesting? giant heat shrink...but how do you remove it? It wouldnt be a good idea on a car that you may modify frequently, trying different manifolds or what not.
      Apr 2004
      OKC, OK
      love them, work great. i won't use anything else
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by MuscleRodz View Post
      me either, I use them wherever I can, never had a failure. I have removed them many times without a special tool.
      Jody
      san diego
      how do you remove them? reheat?
      Rockford Illinois
      Quote Originally Posted by falcon65 View Post
      A razor knife will do it.
      When I removed my manifold, I was able to leave them on and just unbolt the housing. I then just twisted the hose setup up out of the way and then twisted it back when done and it took it well and hasn't leaked yet. I was ready to replace it and thought what the heck ,let's see if it works? Not a drop has ever leaked out from one of the fittings after it got hot for the first time.
      Newbury Park, CA
      The tool is not that expensive and works very well.
      I too will never use another type of clamp if the Gates part will work. If for nothing else my forearms appreciate not being shish-kabob'ed by traditional hoses.
      McMaster-Carr has the best selection and lowest prices.
      Oh yeah, the seach feature..... https://www.pro-touring.com/forum/sh...ht=gates+clamp
      Rockford Illinois
      When using a razor knife to remove them you can buy hooked blades for cutting roofing shingles or flat type stock that will make it easier to not cut into your hose.
      Morehead City, NC
      Been using them for quite awhile with no negative issues. To remove I simple slip a small flat blade under the clamp for some clearance and cut with side cutters.
      Aug 2005
      Hamilton, NJ
      Has anyone used them for multiple years (3-4+) w/o removal? Just curious.
      Scott from NJ.
      Newbury Park, CA
      Yup. Zero problems.
      I used them as well. Got mine at McMaster Carr.
      San Rafael
      I have them on my Camaro and will use them on my Nova and El Camino when I'm ready to hook up the radiator hoses. They work great.
      Paul
      Sep 2009
      Does anyone have pics of them installed?
      Newbury Park, CA
      Link in my sig.
      California
      That looks awesome. So how exactly do you remove them? You guys say cutting, but what are you cutting? The hose or the "clamp"?
      How are you guys reusing them if you have to cut them to remove them?
      Matt
      Matt
      Aug 2001
      Quote Originally Posted by garickman View Post
      Jody
      Aug 2001
      Quote Originally Posted by DarkoNova View Post
      Matt
      I bought the tool, but have removed many of them without it. You cut the shrink clamp, not the hose. The hose is reuseable, but not the clamp, one use only.
